Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Limited or no connectivity problem.. from phil. here!
  • khatkhat52 Sep 15, 2010
    pls help me before my Di-604 router are working but i try to use it again.. but its not working now.. limited or no connectivity.. problem' from Philippines here.. thanks help me po!
    i am using service pack 3 windows xp prof. so do i need to make it sp2? thank you so much sir..
  • 51 Answers
If you are receiving this error, you should run the Microsoft patch (KB884020) for it. Follow the instructions below to do this. Alternatively, you can download a zip file with the patch, registry file,.
1) Download the patch from Microsoft's site
2) Run the update to install it
3) Run this short Registry fix to complete the update. Type the following lines in Notepad and save the file as FixReg.reg on your desktop, then double click on it to install into your registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\IPSec]
"AssumeUDPEncapsulationContextOnSendRule"=dword:00000002
4) Reboot your computer
If you experience the error message again, reboot your computer first. In most cases this will solve many connectivity issues that are not associated with this SP2 bug.
Posted on Sep 14, 2010
  • 7 more comments
    windows xp prof. sp3 po gamit ko.. gagawin ko po pang sp2?
  • Reyaz qamar
    Reyaz qamar Sep 15, 2010
    Please leave a message in english so i understand
    windows xp prof. sp3 i am using.. so do i have to make it sp3? im from philippines sir.. thank you so much..
    sp2** i mean.. sorry..
  • Reyaz qamar
    Try disconnecting one of the other Pcs from the network and connect your
    PC to this port, now check that the network connection has obtain an IP
    address and DNS address automatically (under TCP/IP address properties)
    then go to start
  • khatkhat52 Sep 16, 2010
    i tried sir. but its only giving me an ip address.. and sub mask. do i need to download and install this patch sir? Microsoft patch (KB884020)
  • Reyaz qamar
    Reyaz qamar Sep 16, 2010
    you need to download sp3 updates Microsoft patch (KB884020 and restart the system.
How to replace a pvc valve on a 2001 buick lasabre
Phil the PVC valve is going into the valve cover and only has a rubber hose that leads back to the intake. Why do you think it needs messed with?
Jun 10, 2014 | Vehicle Parts & Accessories
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
HC 40 LIMIT sound system
FIXED>>>>I took it to a local repair centre.
Jun 22, 2009 | Limit HC40 System
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
How do i take the main seat cover off my phil and ted sport
you have to undo the 2screws each side to remove handle, and there are 2 screws on each side near footrest to undo. then it should slide upp the frame and off where the handle bar connects. sounds more complicated than it is should take about 10-15min. then the whole seat can go in the wash.
May 29, 2009 | Phil & Teds E3 Twin Seat Jogger
Phil and Teds Sport. Front wheel either moves freely and falls off when you tilt the buggy up or clicks on and is locked in a very limited position, rotating little left or right. Any ideas?
First of all, I cannot tell you how frustrating the Phil & Teds instruction manual is. Our's had one half inch square pictures that were supposed to be adequate to learn how to use this. As a general suggest there are fantastic videos posted by a third part (not Phil & Teds) that are worth watching.
After several frustrating hours I can tell you exactly how to fix this:
1. Put on the rear brake
2. Sit on the ground in front of the stroller but sit slightly on one side or the other
3. Lift up the stroller so that you can see the pin that you pull to release the front wheel
4. Pull the pin slowly out about a quarter of an inch
5. You should see that there are actually two metal pins (one large, one tiny)
6. Twist the knob you pulled so that the tiny pin does not line up with the tiny circle on the inside of the knob
7. Let go of the knob
If you did this correctly, you should be able to have the front wheel locked in the swivel position even if you tillt the stroller upwards.
I hope this helps. I also hope that at some point Phil & Teds hires someone to help them with their instruction manuals. They have several clever and humorous language in them, but when the document does not serve its actual purpose the humor just becomes frustrating. For the cost of the stroller, the company should be embarrassed that its users are resorting to these online forums to help each other, although I am happy to do it.
Enjoy!
Apr 09, 2009 | Regal Lager Phil & Teds Sport Buggy Double...
Connections
got to practical pushchairs, online store thay do loads of spare parts for the phil and teds bugy and at reasonable prices, plus only 3.99 to post them to you, hope this helps
Aug 15, 2008 | Phil & Teds E3 Jogger
Lumix FX10 - 4gb card reports "card error"
I think you need a SDHC 4GB card. SD is only supported to 2G.
Jul 28, 2008 | Panasonic Lumix DMC-FX12 Digital Camera
No volume control
HI Phil...
The AUX input will not work with a turntable.
The turntable needs a pre-amp before you connect into the Soundspace.
Try www.needledoctor.com for a pre-amp
Apr 09, 2008 | Nakamichi SoundSpace 8 CD Player
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
471 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
