Question about Canon MP-11DX Calculator
Error light on, left bottom corner
The error light is on and I cannot do anything
My calculator has the (E ) and 0 symbol and I can not do anything
Posted on Dec 10, 2008
Try using the tip of a pall point pen to press the reset button at the back of the calculator.
Posted on May 24, 2008
How do I get rid of error on page on facebook
Error pages cant be solved. It's server problem on facebook. Wait until fixed.
Mar 02, 2015 | Facebook Computers & Internet
Abs on vr commodore light stays on solutions
Error logs are a great thing. They will help you find intermittent problems and start you off in a general direction of where a problem could be. There is a great level of detail on the justcommodores site on checking error codes logged by the engine management system, but this does not detail anything about the abs system. The abs warning light is not as common as the check engine warning light. Reading through the posts, I haven't found any detail on checking error codes logged by the abs system.
So here it is. For those of you familiar with checking the engine error codes, this procedure is so simple its not funny.
Basically, to check the engine error log, you bridge the 5th (ground) and 6th pins in the ODB connector under the steering wheel.
To check the ABS error log, using the same trusty calibrated paper clip, you simply bridge pins 5 and 12 of the connector.
To find pins 5 and 12, start at the top left hand corner. That is pin one. Going to the right, you count pin 2,3,4 etc. Once you get to the end, jump back to the start of the bottom left level of pins and keep counting. Pin 5 is about halfway along the top row, pin 12 is a little left of the middle in the bottom row.
Reading the error codes is the same procedure (counting the flashes), except now, the ABS light flashes (as opposed to the engine light when checking the engine codes).
The ABS log also uses code 12 firstly, with any errors logged shown after that. If no errors are logged, the 12 will flash again.
Error codes for the ABS error log (VR/VS) are as follows:
12 Diagnostic system operational
21 Right hand front wheel speed sensor fault
23 Right hand front wheel speed sensor continuity fault
25 Left hand front wheel speed sensor fault
27 Left hand front wheel speed sensor continuity fault
28 Wheel speed sensor frequency error
31 Right hand rear wheel speed sensor fault
33 Right hand rear wheel speed sensor continuity fault
35 Left hand rear wheel speed sensor fault
37 Left hand rear wheel speed sensor continuity fault
41 Right hand front inlet solenoid valve circuit fault
42 Right hand front outlet solenoid valve circuit fault
45 Left hand front inlet solenoid valve circuit fault
46 Left hand front outlet solenoid valve circuit fault
55 Rear inlet solenoid valve circuit fault
56 Rear outlet solenoid valve circuit fault
61 Pump motor relay circuit fault
63 Valve relay circuit fault
71 ABS control module internal fault
The above guide has been verified on a VR/VS. Checking the error log on all models prior to VR/VS is the same for the engine log, and I would assume that the same can be said for the ABS log, would be happy if someone could verify this for me.
Sep 21, 2013 | 2005 Mazda Tribute
Error on page in bottom left had corner
I have a yellow triangle on the bottom left hand corner of my facebook.
I cannot open my home page, chat or write any comments.
When I double click on the triangle it states that I have errors.
Can you help me solve this problem please.
Thanks
Sep 13, 2009 | Facebook Social Network
Problem with facebook homepage
Can you post the error message and/or error code?
Have you tried using a different browser?
Jun 28, 2009 | Facebook Social Network
Error 08 / Disk Locked error
With help of Yamaha tech staff, I inserted a business card under disk "lid" in bottom left corner, slid card to right to release catch. With catch released, pushed disc in to insure in OK, closed lid cover, then slide card from lower right corner to left to re-catch. Read disc OK.
Jun 12, 2009 | Audio Players & Recorders
Exbox 360
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
D3122 has error L2 is there anything i can do or does it need a tech
Pull the power plug. Place a towel well under back right corner. Lift front left corner water will run out of unit give it a minute. When you power back on, the front panel lights will be on but now you will be able to turn off the unit using the power button on top of the door. Any residual water should evaporate over time. Ensure the unit is level and no hoses are pinched or kinked. Test unit if L2 error occurs again it would suggest an internal leak a tech would be needed.
Aug 22, 2008 | Dishwashers
One red light bottom right hand corner
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
1 RED LIGHT BOTTOM LEFT CORNER
This usually means something is wrong with the graphics scaler. You'll eventually have to send your xbox in to have it fixed, and I believe it is covered under a one year warrenty.
Feb 26, 2008 | Microsoft Xbox 360 Console
Canon MP-11DX Calculator Logo
597 people viewed this question
old marine
old marine
