Question about Sharp AR-M205 Copier
What is the solution of sharp ar m205 - E7 /11 error
  • Sharp Expert
  • 316 Answers
E7-11 Shading troble(whifecorrection) IMPRPERCONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE copy lamp lighting abnormality ccdunit abnormality MCUPWB abnormality (when occurred in the scan position)improper installation of the mirrorunit
Posted on Sep 20, 2010
Sharp copier repair code F5-02
Here is a list of all Sharp Copier Error Codes
The Sharp AR-M205 is almost 12 years old now. It will be very hard to find parts for that machine unless you can find a low meter on ebay.
You may want to take a look here at some of the current Sharp copier models. It looks like the Sharp MX-M232 replaced this machine.
Oct 29, 2012 | Sharp AR-M205 Copier
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
capacity.
2. Duplex setting is set for a single surface
model.
Apr 08, 2011 | Sharp AR-M205 Copier
Sharp ar-m205 f2 error code blinking instantly and device doesn't go to service menu
hello,
F2 04 Improper cartridge (destination error, life cycle error).
Try to put back the old cartridge , see if F2 dissapears, or try to put in a new one.
the toner cartridge seems to be the problem.
regards,
Adi
Nov 05, 2010 | Sharp AR-M205 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Sharp AR-M205 Copier
Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
Apr 01, 2009 | Sharp AR-M205 Copier
Sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Feb 28, 2009 | Sharp AR-M205 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
System settings on Sharp AR-M205
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
Dec 18, 2008 | Sharp AR-M205 Copier
Sharp AR-M205 Copier Logo
515 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
