Question about Frigidaire GLTF2940ES Front Load Washer
Washer (laundry) my washer says err lock when you set the settings on it. When you push start it beeps and says err lock.
  • Anonymous Oct 19, 2008
    Thank you VERY much! THis site helped me and saved me a $100 visit. I googled my problem and there you were.
    President:
  • 1,314 Answers
Try pressing options and select for ten seconds if that doesnt work you have a promblem with the door lock switch open then shut your door firmly try it again if that doesent do it try unplugging the unit for 5-8 seconds then retry if that doesnt do it then pull the bottom panel and look on the left side of the washer there will be a envelope with a tech sheet there with instructions on testing the door lock itself
Posted on May 16, 2008
  • 145 Answers
Check the control panel lock. It can get held in while changing clothes. I can't remember what buttons you hold in on that unit but it will say in small print under the buttons on the right side of the control panel.
Ran one load of laundry in washer, started another and the unit just beeps 3times and I push to reset but lid won't lock or start cycle. I tried moving dials to wake up machine but got no luck
My GE top loader has a little "finger" on the lid , when lid is closed it depress a switch inside a little hole , Now YOU with a wood pencil you turn machine on and press the little switch inside the hole, it may have dropped too low for the "plunger". the washer should start. now tighten the screws for that switch.
Jun 03, 2015 | Frigidaire FFLG1011MW Gas Washer/Dryer...
Washer won't start
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 03, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 417.44092500 front load window shows Err then flashes LOC and the minutes for the particular load setting. Door doesn't lock. Tried to get into diag code setting on spin/drain and pushing pause &...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Mar 08, 2009 | Washing Machines
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Kinmore 44092 Washer - can't get it to start any cycle
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off.
Retry the machine with clothes.
Nov 20, 2007 | Kenmore Energy Star 44092 Front Load...
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Frigidaire GLTF2940ES Front Load Washer Logo
67 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
