Question about Samsung DMR57LFS Stainless Steel Builtin Dishwasher
Samsung dishwasher dmr57lfs, is saying 9E, low water level. how do i fix this or reset it
3 Suggested Answers
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
taran_2005
  • 10515 Answers
SOURCE: samsung dishwasher model dmr57lfs does
Here are a few tips, since the dishwasher detergent manufacturers have eliminated phosphate from detergent in 2010. Make sure you run your sink by the dishwasher to get the water as hot as it will go prior to starting your dishwasher. If you have hard water, there is a product called GLASS MAGIC. If you can't find it in a store, buy it online. It contains phosphate and is put into the PRE WASH cup. It's an additive and is used in conjunction with your detergent. That helps tremendously. Also, ensure you're using a rinse aid, such as Jet Dry. If you have calcium in your water, glass magic will help. Your detergent will break down better and you won't have cloudy dishes. Water temp at your tap should be NO LESS than 120 degrees Fahrenheit.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 19, 2011
Dishwasher starts and then stops with 9E flashing in window.
The 9E issue indicates a low water level in the dishwasher. Check your hoses. Make sure that no dishes flipped and filled with water. Make sure that the dishwasher is level. Next check if there is any debris blocking the water level (overflow) sensor. It's in a small square plastic box on the left side of the dishwasher. Pull the dishwasher forward and check for loose or damaged wires to the water level sensor.
If the wiring is good and the error persists, replace the sensor. Replace the wiring if it is damaged. If you add a comment with the model number, I may be able to point you to the replacement part. If your dishwasher is under warranty, contact Samsung for the repair.
I hope this helps.
Jul 04, 2016 | Samsung Dishwashers
What could be the problem on my Samsung DMR57LFS dishwasher with an E9 error after the low-level sensor is cleaned but the error still exists?
This is an exhausting procedure you have described here. Have you checked the float in the low water reservoir is actually working.
Sep 15, 2014 | Dishwashers
I have a Samsung stainless steel tub dishwasher and only 2 months after we had it installed we had all sorts of issues with it. We were lucky it was under warranty and turned out parts needed to be changed - upgrades from Samsung that were not done i nthe store where we purchased the dishwasher.. You may want to check with Samsung with your Mode land Serial Number you never know, there might of been a recall. Good Luck!
Sep 15, 2014 | Samsung DMR57LFS Stainless Steel Builtin...
Error code oE
According to page 25 of the users guide you can download from Samsung's web site at http://www.samsung.com/us/support/owners/product/DMR57LFS oE means, "Water level error (over-level)"
Jan 20, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
9E error code on dmt800rhs dishwasher
I also had the 9E error code on my Samsung dishwasher DMT800RHS mmodel. I had to call Samsung and the nearest authorized Samsung service representative came to my house last Tuesday, January 29, 2013. The cost of the call is $100 which really annoyed me off considering the dishwasher is only 1 1/2 years old. Two South Korean guys showed up and to fix the problem just press down on the Heavy, Delicate and Power button at the same time for a few seconds and a menu will appear on the top left hand corner of the panel. Scroll down the menu by pressing the Normal button until you reach "FT" and the dishwasher will automatically fill up and then autimatically drain. If it does not drain then scroll down to "S" and the dishwasher will drain. Thsi should get rid of the 9E error message and your dishwasher will work fine but if not you have to repeat the procedure maybe 2 or 3 times until the 9E error message disappears. If you constantly get the 9E error message then you may need to replace the part which is about $60. The part is extremely sensitive to either hard water or food particles which is why the 9E error message appears. Therefore, scrape your dishes thoroughly so the food particles are minimized and the sensor does not go off which causes the 9E error message.
Nov 21, 2012 | Samsung DMT800RHS Semi-Integrated...
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
Nov 14, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
We have a samsung dmr77xxx dishwasher and it keeps getting a 9E error and stopping> what is causing this error? thank you
Most 9E error codes are caused by a sticky float located on the LHS of the dishwasher. You can sometimes do a temporary 'fix' by 'thumping' the left panel inside the dishwasher (towards the bottom).
Aug 23, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
Low water level error with a new samsung dishwasher. Only 3 months old. What could be the problem?
Do you hear the washer draining (into the sink drain) after it fills and should start washing? Check that nothing (sound deadener, etc.) is interferring with the drain valve lever arm.
Jan 09, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
Unable to reset after LE problem.
LE is a Leak error, the leak sensor is on the very bottom of the machine. you can let it sit for a while till the water dries and it will start again. If it happens again then you'll have to call for service, that or pull out the unit yourself.. prob. not recomended.
Apr 01, 2010 | Samsung DMR57LFS Stainless Steel Builtin...
Samsung DMR57LFS Stainless Steel Builtin Dishwasher Logo
787 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
