Question about Dell Inspiron 530 Desktop Computer
All of a sudden the pc wont work can start the pc and it's running but just getting a beepeing noise roughly every few seconds help please. Rich
    Scholar:
  • 119 Answers
The beeping your hearing is a code, Without knowing how many beeps it's hard to tell what is wrong, But usually indicates a Power Supply issue or even a motherboard issue those are extremes it could be that your hard drive is no longer booting, Or the operating system isnt being found, Usually though that beeping is not a good sign.
I would suggest when your computer starts beeping it is time to seek help from the pc repair shop in your area check craigslist usually some adds on there for inexpensive work
Posted on Sep 14, 2010
The PC won't start, won't even reach the boot up stage. Keeps tripping and trying to power back on.
Open it up and turn it on and see if the power supply fan stays on if not replace it.
If it was a bad memory chip the beeping wouldn't stop.
Feb 29, 2016 | Computers & Internet
Had ticking sound started up this am loud pop then rough running like there was no muffler
Ford Windstar Starting/Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... I tried to startmy van on a 15 degree morning - heard a loud bang and now it won't start. Battery ....The engine will crank, start run about 5 seconds then stop. ... I have a 2003 Ford Windstar, same problem,Ford is covering up the problem.
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
As a rough guideline, problems with the battery, alternator and starter are the most ...Before I even put the key into the ignition I hear a clicking noise on the right side ...started it and then it started making a loud clicking noise while I was driving it ..... i have a 2003 windstar ford it was clicking and wouldn't start had to get a ...
Rough Idle Engine Dies Loud Ticking!?! Please Help! - Ford Focus ...
www.focusfanatics.com/.../103146-rough-idle-engine-dies-loud-ticking-...
Nov 6, 2006 - Rough Idle Engine Dies Loud Ticking! ... down then dies and then i restart and it has no problems but the ticking continues PLEASE HELP ME ... Level Up0% Completed ... 2. my injectors are bad and the ticking sound is one of the injectors.... Another method is to turn the AM radio on to a place where there ...Missing: windstar
Jan 08, 2016 | 2003 Ford Windstar
1986 Ford Tempo 2.3L, CFI - Why won't it start?
Black smoke is typically a rich mixture, so don't over look the obvious, perhaps air filter is dirty, so often overlooked. Something could be blocking air flow, but MAP usually produces lean situation more so than a rich mixture. Vacuum leaks usually cause rough idle, but not overly rich mixture. Perhaps you choke system is problem as well, this can be sudden issue as well.
Dec 10, 2015 | Ford Cars & Trucks
Lg ibm multinet i tower allows power to the motherboard but wont start up, what should i do?
remove the power cord, remove the bios battery, short the two contact together in the battery holder for a few seconds, replace the battery and power cord and try again.
if that doesn't work, start removing items/plugs (not the big 20/24 pin one) from the motherboard until you get beeping noises.
if still nothing then put everything back and try a different power supply.
if that doesn't work, your motherboard is probably dead.
Apr 18, 2014 | Computers & Internet
07 impala starts but dies and not start again
Normally Shifting out of gear in motion wont damage much unless you revved the engine really high for an extended period. Shifting into park while in motion will make a ratcheting sound, but usually wont hurt anything. However the act of doing so may have tripped a fault in the ECU that makes the car think it needs to be in limp mode. It did just that and got you home albeit running roughly.
Have someone remove the NEGATIVE battery cable. leave it disconnected for a few minutes, then reconnect and jump start the car if the battery is too low. doing so should reset the ECU and restore normal operation. If drivable, proceed to a brand name parts store. they usually will reset your ECU codes for free. IF all is well this should fix the probelm. If something was indeed damaged, you wont likely be able to drive the car.
Jan 11, 2013 | 2007 Chevrolet Chevrolet Impala LT
95 nissan truck won't rev and runs rough
sounds like it's running in closed loop. O2 sensor, MAP sensor, or MAF sensor...sensor issues
May 18, 2012 | 1995 Nissan Pickup
I have a 1997 Saturn SL single cam 1.9L. I'm having a problem with not wanting to start without giving it gas and it is fuel injected. And once it is started it runs rough for few seconds then smooths...
Before anyone can answer you with certaincy, you would need to run a compression check on your engine. Basically, if your engine has good compression it will last and the repairs you should make are rather minor. If the compression test shows one or more bad cylinders then you could be looking at major repairs or engine replacement.
Where you said the spark plugs were black, yes it could be too rich but it could also be bad rings that the compression check would find.
I know this isn't what you want to hear, but I would rather not tell you something I am not sure of. But your computer isn't telling you that you have major problems so maybe things are just gunked up, that a good road trip where your vehicle will stay at operating temperature for an hour or two would clear.
Aug 26, 2011 | 1997 Saturn SL
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
Beeping noise after installed memory on ecs motherboard L4S5MG
Some older computers, like mine, have a maximum memory they can handle. This one happens to be 1 gig, but yours may be less. Do you have an older computer? Yup, you do. As seen here, the maximum supported ram is 256. I'm sorry. Please rate.
http://www.dealtime.com/xPF-E-Machines-eMonster-500a-EMONSTER500A
Jun 18, 2009 | E-Machines eMonster 550 PC Desktop
Dell Inspiron 530 Desktop Computer   Logo
149 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
