Question about Coleman Powermate Premium Plus 6250W Portable Generator
Wiring diagram for 110v to 240v change over switch for a bulldog bge3000cv generator
3 Suggested Answers
  • 3 Answers
SOURCE: plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Posted on Mar 14, 2010
sal_kh_sab
  • 98 Answers
SOURCE: wolf generator fitting a new switch 110 v to 240 v
frank...send me a photo of this part and other photos wll be helpfull....i'll be glad to help u /...
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
How do I check the internal wiring for input voltage on a Marantz 4060 Quad Amp?
The only way would be a voltage selection switch on the back of the unit, or changing pigtail leads on the primary side of the power transformer.
Apr 30, 2014 | Marantz MA-9S1 2-Channel Amplifier
Tip
Dynaudio BM - Power from 110V to 240V or 240V to 110V
Hi Guys,<br /><br />This is what I have learnt the hardway so wanted to share it with everyone who wants to get his Dynaudio Speakers converted from 240V to 110V or 110V to 240V.<br /><br />I actually requested many forums including Dynaudio Support as I bought mine from US and they were 110V, I wanted to use it in my Country which has 240V standard, What these guys suggested me was to order the whole AMP Modules for the speakers if I want to have them work in my country. In other words it was a solution of $350 per module totals to $700.<br /><br />Shame on them as I opened the speakers myself and found a small jumper wire hooked up on the connections marked 110V and there were other connectors marked with 220V and 240V.<br />All I did was just took out the jumper from 110 and inserted it in 240V connectors!!<br />Thats about it!<br />So guys forget these mean techiz at Dynaudio and use my experiene to solve your problem :-)<br /><br />Cheers<br />Satch<br /><a href="mailto:satchriani2@hotmail.com">satchriani2@hotmail.com</a>
on Apr 04, 2011 | Dynaudio Acoustics BM6A MK II Active...
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
Which part need to be changed in dewalt 680k planer to make it work with 240v insted of 110v, we do not wont to get a step down transformes thanks
Some of the more expensive motors have a jumper setup within the motor housing where the cord enters the motor. If it is possible to re jumper for 240v it will give a diagram on the cover plate where the wire enters the motor usually. If this doesn't work you might contact dewalt. You might have to change the whole motor.
Aug 03, 2011 | Kitchen Ranges
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
May 25, 2011 | Air Tools & Compressors
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
http://waterheatertimer.org/Paragon-timers-and-manuals.html
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Aug 21, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
Plug wiring diagram for 240v outlet 7000w blackmax
Dec 25, 2009 | Electrical Supplies
Need to change wiring from 220V to 110V
Black or red is hot; green is ground; white is your neutral. The black should be for 120 and the red for 220.
Jun 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wolf generator fitting a new switch 110 v to 240 v
Mar 03, 2009 | Coleman Powermate Powermate 5000W...
Coleman 7000w gen. I have 120 on only one side of my 240 plug. I disconnected wire assembly from control box.. Could get 120 out of various combinations of the 4 wires but never 240. Should I be able to?...
At the wire assembly there should be 2 white and 2 black wires, a white and a black are the ends of one 110v winding. With the 2 white wires connected together you should get 240 from the black wires. This sounds like it is a problem with one of the circuit breakers in the 240v outlet in the control box, check them with an ohm meter.
Regards,
Carl
Jan 31, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
944 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
