Question about InVion 4NAVV1 GPS Receiver
The suction cup on the GPS holder will not stick to the windshield. Needs replacing. How do I get one and how much will it cost?
  • 944 Answers
It will cost around 13-14$.You can order in online or you can get in the InVion service center.Many GPS holder model will fit your InVion 4NAVV1.
1-800-817-3858 call this no and get your local area InVion service centre address.
http://www.bizrate.com/miscellaneous/oid2089754291.html
http://www.dealtime.com/-invion+support+plus+navi
http://www.phbahiaobarrio.com/invion-gps/
http://www.retrevo.com/s/Invion-GPS-7V106-IUS-GPS-review-manual/id/2847ci876/t/1-2/
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 14, 2010
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Jan 04, 2011 | Tomtom ONE XL GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Dec 31, 2010 | Tomtom GPS
How exactly do i fix the suction back onto the windscreen please? I have just bought a tomtom and don't understand the drawings!
Dec 31, 2010 | Tomtom ONE GPS Receiver
Mount no longer sticks to windshield
Well a new mount suction cup will need to be purchased. you can grab one at radioshack.com you alsmo might want to wet the plunger then try to stick it. Or clean of that dirty windshield and try again.
2 solutions
1. clean the windshield and apply a little water to the back of it.
2. Buy a new suction cup.
thats all I hope you to stop by and rate it thanks.
Apr 16, 2010 | Tomtom ONE GPS Receiver
Suction cup does not stick to the base of the tom tom..Everytime I try to attach the suction cup, it just falls over. Help
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
Feb 06, 2010 | Tomtom ONE GPS Receiver
GPS will not stick to the windshield.
Check to make sure that the suction cup you have is the appropiate size for your GPS unit. Also check to make sure there is no grease or other slippery substance on the windshield or suction cup that stops it from sticking to the surface. If you have something like Rain-X on your windshield, you will need to clean the area where the suction cup will be placed, and after that, it should stick.
Oct 29, 2009 | Garmin StreetPilot C330 GPS Receiver
Plastic pholder for my Garmin 255W will not stick to windshield
The glass and attachment suction cup should be clean and free of oils, dust hair etc. Try cleaning both surfaces. If this doesn't workyou can order a new holder from Garmin.
Aug 02, 2009 | Garmin Nuvi 255 GPS Receiver
Windshield Mounting Unmounting
first the round plate... that has a sticky circle on the bottom.... you remove the tape and stick it on a surface where you want the gps... then when you want to mount the gps you suction cup it to that disk. now for the suction cup... when it is disengaged the plastic suction cup will be loose. to attach it to the plate or window... you swing the small arm on the base of it up or down... you will see as it will lock the suction... the gps should clip onto the holder so you can leave the holder where it is and remove the gps and slip it into your pocket.
Not the best instructions but you will get the idea
Robert
Please take a moment to rate this solution thanks
Jan 24, 2009 | Tomtom XL 330 Car GPS Receiver
Holder
wet the suction cup a little, press down firmly before flipping the switch to lock it down
Apr 18, 2008 | Garmin StreetPilot c340 GPS Receiver
InVion 4NAVV1 GPS Receiver Logo
125 people viewed this question
Top InVion GPS Experts
Will Halftowaite
Are you an InVion GPS Expert? Answer questions, earn points and help others
