Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Screen is black but there is sound
Last week I turned the TV on it was dark(light was blue) but there was sound. This was on the DVI setting so I check on the component and the same condition existed. I shut the TV and tried it again a few hours and it was fine then the next time it was black again and hasn't worked since(from a picutre stand point) thoughts
  • Anonymous May 18, 2008
    The same problem!
    Genius:
  • Westinghouse Master
  • 1,689 Answers
It is possible that the backplane lamps and or the ballast supply is in failure. It is also possible that the main power supply is having a fault condition, or there is some other area that is shorting and causing part of the power supply to go in to protect mode.
The set should be checked out by a service tech who knows the set, and has the necessary resources to service it.
Jerry G.
Posted on May 16, 2008
Samsung LN37B530 37" LCD TV
Sounds like your Tcon board is giving issues.
Nov 16, 2017 | Samsung Televison & Video
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
When I turned on TV, sound was ok, but there's a black screen
Same thing happened to me. I turned TV off. Then turned it back on holding down both On button & Source button & got the picture back. Doesn't fix it for good. But when it happens, I "fix" it the same way. Happened twice in last three weeks, I'd say. Better than junking it for now.
May 10, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
HAI
Start by going to a good college and studying electronics 101 followed by electronics 102, math, algbra, etc, until you get an engineering degree. Now as for the dark purple and blue. It sounds as though you have a picture tube getting weak in the red gun and unless you can turn the red gun up you may need a new set. Anyway, good luck and have a great week
Ed
NC Electronic
MIlls Wyoming
Jan 06, 2008 | St. Moritz Bellagio Flyback Chronograph...
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
83 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
