Dr Sirs ... I am using a Packard Bell Monitor , the L 15 c . But there is no user manual . So I can not choose all menu options , like contrast . Please .. can you help me with a booklet or manual of this monitor ? Or perhaps send it in a PDF file / I would be very thankfull. greetings : Stef Macrander
SOURCE: X2gen MW19R user manual
Can you send it to me???? tmill79755@aol.com . I bought the same monitor from e-bay without a power supply (of course). Can I use a 12v/4a generic one??430507
Posted on Sep 27, 2008
SOURCE: Unable to adjust contrast
http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
Posted on Oct 07, 2008
rockitman187
  • 2559 Answers
SOURCE: Fn combination keys for external monitor
Key Combination Functionality
Fn+F3 Reduce speaker volume
Fn+F4 Increase speaker volume
Fn+F5 Switches display: LCD, CRT, and LCD/CRT simultaneous
Fn+F6 Increase LCD brightness
Fn+F7 Decrease LCD brightness
Fn+F10 Toggles battery warning off and on
Fn+F11 Switches the LCD panel off and on
Fn+F12 Places the computer into Hibernate mode
Posted on May 22, 2009
stevenhurc
  • 450 Answers
SOURCE: nubira 2000 user manual pdf manual (english)
try this link to manual even though its 2004 manual is basically same just they updated info and put all paper based books into electronic form.(this link works !!)
http://www.onlinefreeebooks.net/automotive-machinery-power-equipment-ebooks/daewoo/daewoo-nubira-lacetti-service-manual-my2004-transaxle-drive-axle-pdf.html
Posted on Jun 26, 2009
  • 732 Answers
SOURCE: brightness/contrast pop up,options toggling randomly can't select
sugars_30, You or electronics technician will need to (most likely) fix the units "switch-mode-power-supply" !!! Do some extensive reading in my fixya profile and follow the links to other "cold-cathode-fluorescent-lamp" back-lit lcd monitor tech's here on fixya. They and I already have written tons of stuff that will help you to understand the problem you have. When "strange stuff" starts happening with a ccfl lcd display, the first place to look is at the innerds of the monitor. Just do some reading!!! 12fixlouie
Posted on Apr 16, 2010
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
How to find the model of my easynote packard bell
1 Turn the EasyNote notebook computer on, and allow the operating system to boot up completely.
2 Click the "Start" menu button. Choose "All Programs" followed by "Accessories," "System Tools" and "System Information."
3 Click the "System Summary" option in the left pane of the "System Information" window.
4 Locate the "System Model" entry in the right pane. Directly to the right of this text, in the "Value" column, is the model number for your EasyNote notebook computer.
Jun 03, 2011 | Packard Bell Computers & Internet
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
The picture is too big for the screen. The four buttons will only adjust colour and contrast - not size
To adjust the screen size (resolution) you have to right click on an empty place on Desktop, select Properties and then Settings. Under screen resolution change it to more, until it shows under it 1024x768, or even bigger if you want and it is possible.
Dec 22, 2010 | Packard Bell 15".28 1024x768 Beige CRT -...
I have a second hand packered bell laptop, how can i check the batery power?
for xp go to start, settings, control panel, power options, power meter will display it. start, settings, control panel, power options, advanced, then checking display on task bar and applying will put it on task bar.
Aug 10, 2010 | Packard Bell FT500 15" LCD Monitor
User guide
Hate to say it but it looks like you are going to have to learn from your mistake i think system restore is your only option unless you install a program called Recuva 1.38.504 from filehippo it allows you to get back files that you have lost
Jul 28, 2010 | Packard Bell Packard-Bell Full Page...
Download driver packard bell ft500
download drivermax and it will scan ur pc and tell u what driver u need for ur pc........its free if u take the free site.....
if no help with this go in touch with dell service department and ask for help
Jul 03, 2009 | Packard Bell FT500 15" LCD Monitor
On start, monitor contrast option automatically gets activated
if nothing works and you cannot access your monitor settings via the menu button on the monitor then you have no way of correcting it. as far as i am aware the only thing you can change with the monitor from within your operating system are its resolution, refresh rate. so i think you need a knew monitor.
Apr 23, 2009 | IBM E54 15" CRT Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Packard bell registration message
There is a solution for this problem, but you have to be very computer orentated to correct it. First look in the programs listing under startup and see if there is a link there for the PacBell auto start when the computer tarts each time it is turned on. If there is a link there right click on it and delete the shortcut from the startup menu. restart the computer and see if it is still there. if so go back and look in the startup menu selection and see if it has reappeared. If it has then you will have to shut off the windows auto recovery option so it will not replace the missing file when the computer is restarted. Now if this does not work, you will have to get someone that is familiar with the registry files. You do not want to go probing around in there or you may just shut down tour computer permanently. A professional will have to go in and search for the file entry that controls the option and then delete the corresponding registry entries. Regards, rcampsr
Sep 28, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
