The hinges on the right side of my laptop monitor appear to be stuck. I cannot close the monitor or the monitor begins to come apart at the seams.
    Problem Solver:
  • 17 Answers
If you have no idea how to disassemble it then search website to find one very close to your laptop type. you should be in earlier steps (usually after the KB taken out) to take apart screen and then you can examine any damage or not. if something broken then you need to buy the part to replace. Otherwise after you put back it should fix the problem.
Posted on Sep 14, 2010
Samsung R519 laptop screen blank -apart from when lid nearly closed??
There is a tiny on/off switch, that controls the backlighting when the lid is opened/closed, located near the hinges, usually, on a laptop, sometimes the switch will stick due to dirt ,dust, loose hinges...etc. locate the switch and free it from its obstructions, if any.
Nov 12, 2012 | Samsung R519-53S Notebook
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
Powering on the laptop does not turn on the display at all.
Most laptop screens connect to the motherboard(and therefore to power) through a small cable which generally runs very close to the hinge on the right hand side.
This cable can come loose.
If your laptop appears ok in all other ways this might be the issue.
Just plug a normal monitor into the back and youll see if the laptop itself is working ok.
To reseat this cable involves opening up your laptop, which I wouldnt recommend if it is still in warranty or if you're not too sure of yourself
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
I need to remove and replace my drivers side door and do not know how to do so.
go look at the passengers side. take note of the door seam and fender seam width. its about the width of a piece of cardboad. additionally look at the door hinges on the passenger side. it may or may not have washer shims. if they do/dont then just match up with passenger side. it takes 2 people to hang the door. screw in door hinges "finger tight" just to take off the weight of someone holding the door. play with the hinges until you can open/close door without binding or crimping fender at the seam. do not over tighten hinge bolts until the door opens/closes unobstructed. bottomline 2 people needed. slow and tedious job. you may have to add or take shims(washers) out for good fit. note that you may have to add shims to the inner door hinges or to the fender hinges where they meet. hope this is clear instructions.
May 30, 2009 | 2002 Pontiac Grand Prix
UNABLE TO CLOSE LAPTAP NO FREE MOVEMENT ON LEFT SIDE
I believe that's the hinge screws on the computer that's too tight. If you have screwdrivers that can fit into the hole of the left hinge, you can just loosen them up & that should fix it. If you're not sure what to do, just take it to a local store and have them loosen them up.
Hope this helps.
Oct 03, 2008 | HP Pavilion dv9000z Notebook
Monitor dark; hinges broken
He may have damaged the inverter or left the cables disconnected from the backlights. The inverter supplies the required voltage to the LCD Back lights.
Mar 31, 2008 | Toshiba Satellite A25-S207 Notebook
Stiff hinge pin
These systems use a pretty generic hinge set-up. These can be dealt with in two ways, one involving a safer method for future adjustments. The hinges are two separate bars on each side of the monitor with friction cuffs that use the tension between their two pieces to hold the monitor stiff. Generally my experience with Acer models is that they ALL ship with pretty stiff hinges, which is a double-edged blade. Stock hinges that don't click when fresh have a tendency to need replacing after a couple years, where as my acer TM4K hinges are still strong today after 4. The best way to loosen these babies up is to just use it. About an average of 75 open/close cycles break in the hinge to where it stays nice & tight, but stops clicking or cracking. The other way, which is for those who are afraid the LCD housing will crack it's so tight, is to take the monitor off, but not apart, carefully using two pairs of needle-nose pliers, hold steady the monitor end with one set and with the other, flex the flat end of the now loose hinge back and forth as far as you can get it to move until you feel it is to the right strength.
It helps to mention that too little is better than too much, as I see a good amount of people burnt out with their Compaq Evo & Presario (ca.2001-2) hinges, falling to the ground soon as you let it go, only 6 months after their last replacement set.
Nov 06, 2007 | Acer TravelMate 2300 Notebook
Broken hinge
It is a snap together construction. a fine blade along the seam perhaps But if you have doubts about that I certainly would have- How about Gaffer tape? I have made many hinge type repairs [not a lappie admittedly] on stuff like the tool cover on a vacuum cleaner- it gets tacky after a while and will need replacing- but far better that trying to rip a clam shell apart.
Jun 13, 2007 | Acer TravelMate 508DX Notebook
Computers & Internet Logo
David Payne
David Payne
