Question about Toshiba Satellite 1135-S155 Notebook
DC jack broken
I need to take apart my Toshiba Sat 1135-S155 to fix the dc jack.
I have a replacement on the way...
Where should I get good screwdrivers for those tiny screws ?
Where can I get service and repair manuals for this model to learn from ?
What soldering iron do you suggest ?
What rosin core solder size or other type should I use ?
What questions did I not know to ask ?
Thanks,
Greg
  • 36 Answers
My computer repair company aka my username does this repair all the time. Here what you should get.
1. 30-watt iron
2. Light rosin solder ( i think Im using .028)
3. solder ******
4. desoldering braid
Here are some toshiba manuals
When taking apart the laptop I pretend a piece of paper is the laptop and I'll draw holes on the paper to represent the screw holes on the actual laptop and when I unscrew a screw I will take in onto my mock up paper. So I will have a paper for all the bottom screws, a paper for the top cover screws, paper for the motherboard screws etc.
When you finally get the motherboard out of the case, desolder the old jack(from the underside) use the solder **** first and then the braid. Once all 5(usually) pins are desoldered wiggle the old jack out. Then put the new jack in and solder it to the board (on the underside)
Posted on May 16, 2008
  • Jason Disbrow May 18, 2008
    Greg if your reading this, someone is trying to sabotage my rank, please rank me. Also the censored word in 3. Solder Su(ker
Need to reset the admin password by removing the cmos battery on my satellite 1135-S155. Have not been inside before and do not want to just start taking things apart. How to I get to the CMOS battery?
For the BIOS password reset of your laptop, I wont recomment to dismantle your laptop on your own. My suggestion is to contact Toshiba to reset it. Mostly for the portable computer manufacturer had a tool to generate a generic password to bypass the bios password to reset it, if there's none have it serviced to depot or a technician.
Hope this will give you an idea in resolving it.
Thank you for choosing fixya
Mar 01, 2011 | Toshiba Satellite 1135-S155 Notebook
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Nov 22, 2009 | Toshiba Satellite P25-S607 Notebook
Drivers for the Toshiba Satellite 1135-S155?
I have fond the model on the ASP website for Toshiba, the link that you will need is the Toshiba Ask Iris help desk. You can download most of the drivers for the laptop here.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=1135-S155&x=0&y=0
Based on the model number you game me your laptop is actually one of the below models,
Satellite:1715XCDS
Satellite:1675CDS
Satellite:1695CDT
Satellite:1625CDT
If you can provide the exact model I can get you the entire driver series. or just click here to download the drivers..
May 27, 2009 | Toshiba Satellite 1135-S155 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Steps to replace DC power jack L15-S104
its not so easy to replace you dc jack please don't try your self....
Apr 25, 2008 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite 1415-S173
Hi
DC jack replacement is easy however requires a bit care since its mounted on the mainboard. Desolder the old DC jack. Solder the new one firmly. Dont keep the soldering iron too long on the PCB as it will damage the lines and will deform the DC Jack. You can get DC jack very low cos from local repair stores or you can order from Toshiba parts depot (800-524-8338)
Please post your question if you need further assistance.
Good Luck
Feb 09, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Toshiba Satellite 1135-S155 Notebook Logo
155 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
