Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman LT2000 riding mower with the 42in deck. I removed the deck to clean it and to replace the blades. When I flipped over the deck, the whole pulley assembly came off springs and all and I cannot for the life of me figure out how it goes back on! I've looked at the exploded parts diagram and can make out where 2 of the springs go but cannot figure out the 3rd one. Also, it seems weird that the whole assembly is only held on by 3 spings. Am I missing parts or just not getting it? Please help, thanks
  • 760 Answers
SOURCE: need a deck diagram for
Copy and paste this web site into your browser.
http://www.managemylife.com/mmh/owner_manuals/27240/CRAFTSMAN-Lawn,-Tractor-L9080013?brand_name_search=917258562+CRAFTSMAN
Page 22
If the link doesn't work, go to www.searspartsdirect.com Put in the model number of your tractor. Then look to the right for a button for a manual. Click there.
Posted on Aug 12, 2010
  • 148 Answers
SOURCE: i need to know the route of the drive belt around the pulley syst
go to www.searspartsdirect.com and you can look up the diagram on their website.
Also you can download a free owners manual at www.managemyhome.com.
Posted on Jul 22, 2009
rycgl
  • 1545 Answers
SOURCE: I have a sears craftsman riding lawnmower LT2000
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Posted on Aug 14, 2011
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 138 Answers
SOURCE: Craftsman 42in mower deck spindle breaks and Strips.
there are thousands of these mowers out there, and most people do not have the problem that you are experiencing - let's face reality, you are hitting something, that's the only way these break - it is impractical to make a machine that will mow through rocks, stumps, and water pipes and not break - also, sears does not MAKE anything, they contract companies to make products for them - if you want a thicker, tougher mandrel housing, log onto www.amcpartsstore.com. they recently began offering a heavy duty version of the mandrel housing, part no. 130794. i've seen these and they are definitely beefy - just be sure to put everything together correctly and tighten all the nuts and bolts firmly, and try to avoid the rocks and stumps
Posted on Aug 26, 2009
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Disengaging blades when mowing completed
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
981 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
