My Omega RD8250 temperature recorder is giving me a "Format Card' promt when I attempt to name my file.
3 Suggested Answers
  • 85 Answers
SOURCE: This camcorder does not record video; it won't format memory card
do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
Posted on Mar 13, 2010
85Sloth
  • 104 Answers
SOURCE: Hi, How to format external hard disk whose file
OK try this
USING DMZ When you enter into your router config window, you need to find the Tab DMZ, it should be under applications and gaming if you are using Linksys. Once you find the DMZ tab, click enable and type in the last digits of your XBOX into the box below. Yes when you do this you are opening all the ports on your Xbox, which is insecure, but show me someone that has hacked into an xbox 360?
<MAKE SURE YOU SAVE SETTINGS>
Using Port Fowarding After you have enabled DMZ, find the Port Fowarding tab, should be under advanced routing. For the name type in XBL or whatever you want, and for port range put 87 to 89, choose UDP, then your XBOX last digits, and enable. Then do 3073 to 3075 choose TCP, then your XBOX last digits, and enable. Then again do 3073 to 3075 choose UDP, then your XBOX last digits, and enable.
after done - then cold reboot both Router and Xbox
XBOX go to the system blade, choose network settings, then test connection. This may take a bit, but when it gets down to NAT type it should say OPEN.
Posted on Aug 21, 2010
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
Unrecognized File Format
Try formatting the card. There should be somewhere in the menu of your camera an option to format the card - this is different than erasing everything, it's like a total wipe of all information on the card. Give it a shot, might help!
Jul 30, 2012 | Kodak EasyShare Cameras
Omega Lexicon sound card refuse to set up
If you are trying to set it up on a new computer it probably has Winsows Vista. The older cd is probably setup for Windows XP and below. You should be able to download the Vista installation package & drivers from the manufacturers website. Just click the Support link and lookup your specific model #; select Vista as the operating system and the files should appear. Download and Install and you should be all set. Hope this helps.
Aug 11, 2009 | Lexicon Omega Desktop Recording Studio...
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Video camer
I was unable to change the file format in which the camera on my phone records, but... unfortunately, I formated my media card, and it works fine now, yes, I erased everything I had on there, but.. I have since reloaded everything I had backed up on my p.c. and commenced recording video's and it works!!!
thank you
Feb 27, 2009 | RIM BlackBerry Pearl 8100
Replace Lost CD
HI I WILL SEND THE FILE TO YOU
IN ISO FORMAT
AND I WIL UP LOUDE IT
IN TORRENT FILE THE NAME IS FILE
----- RR-US360 - IC RECORDER ----
GIVE ME FEW DAYS PLZ .... :)
Feb 20, 2008 | Panasonic RR-US360 Digital Voice Recorder
Unerasable Files
well..im not a fan of the sandisk firmware specially the low sound...
but, have u tried using another firmware? such as rockbox?
Nov 03, 2007 | SanDisk Sansa e260 MP3 Player
File number reset each time i offload footage
Probably you have solved it by now, but here goes anyway. Do not delete ALL files on your computer. Copy what you wish to keep but leave all the files on the card, then format the card in the camera or erase all. Check the setup menu, there should be card format or the like.
Oct 05, 2007 | Panasonic HDC-SD1 Camcorder
Computers & Internet Logo
David Payne
David Payne
