Question about GE GBS18KBM Bottom Freezer Refrigerator
Freezer warnm up
We have a ge bottom freezer fridge.  about twice a day at some point in the day,  the motor for the freezer clicks on and the unit proceeds to heat up to about 8 degrees, sometimes even higher.  it takes about a few hours for it to get back down to 0 degrees which is what it is set at.  during this time the ref tends to stay at it's set temp at 37.  we've had this looked at twice and everyone says the unit is working fine.  it is 3 years old and starting doing this about a year ago.  we are having a heat wave and now the thing has been stuck at 14 all day and the motor is chugging away. the outside of the unit is very hot to the touch when it is working it's way down to the desired 0 degrees. is this supposed to happen?
  • 145 Answers
It does sound like the normal defrost cycle. Aslong as it stays at an average below 12 degrees it is normally working fine. Check to make sure the back air vents and front grille are clean and the fan by the compressor is running when the unit is on. It has to get rid of the heat so it will freeze.
Posted on May 16, 2008
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Fridge is not cooling but freezer is fine
Yes ! in most french door bottom freezer units there is a fan in the freezer behind the back panel that supplies air to the freezer as well as the frig. When the DC motor on the fan wares out the rpms reduce to the point that the volume of air supplied to both components is reduced to a point that the fan will support the freezer but not the frig. The price of the fan motor alone is around $80.00, if all of the components for the fan are replaced the parts will run about $200.00, if you are not going to do the work yourself it will probably cost in the neighborhood of $300.00 parts and labor.
Jul 12, 2009 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge is making a constant clicking noice
Had the same problem on my GE bottom freezer fridge. It finnaly died a few days ago. The clicking came from a relay on the main circuit board under a access cover on the back of the fridge. Ordered a new circuit card from GE ($157.50 + ship/handeling), replaced it, and the fridge works great. I have an electronics background but if you take your time and are safe, I think anybody would be able to change it.
Nov 28, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
I have a ge bottom freezer and now it is making a clicking noise and the temp lights are blinking in rythem with the clicking noise
Had the same problem on my GE bottom freezer fridge. It finally died a few days ago. The clicking came from a relay on the main circuit board under a access cover on the back of the fridge. Ordered a new circuit card from GE ($157.50 + ship/handeling), replaced it, and the fridge works great. I have an electronics background but if you take your time and are safe, I think anybody would be able to change it.
Aug 01, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
PDS22SBRLSS
Hi is there any ice built up at the back of the freezer. is the fan motor going if no ice or frost build up in freezer and fan motor is going . check the compressor. thanks the appliance doc
Mar 09, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GBS18KBM Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
