FixYa.com
Tags:
Saeco Magic De Luxe Espresso Machine
Brewing stops mid cycle
posted by 5504 on May 16, 2008
Hot water light goes off mid cycle and brewing stops.
Problem started half year ago. Boiler started leaking one month ago.
Replaced boiler but brewing still stops mid cycle, so scaling is not the problem.
Also replaced spring and glass ball in brewing unit.
Tried bigger coffee dose for more resistance and lower flow. No help either.
Can't imagine the thermostat in both the old and new boiler are defective.
Any suggestions please????
Chris
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 22, 2008
Not Rated (0)
EspRoastTech
Rank:Wiz Wiz
Rating: 87%, 14 votes
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Coffee and Espresso Makers problems?
The far left light
Hi, The far left light on my... Answer This...
need replacement gasketor seal...
need replacement gasketor seal... Answer This...
I just bought a Krups
I just bought a Krups machine... Answer This...
Stops Mid Brew Cycle - Saeco...
Just stops brewing when the... Answer This...
The Coffee isn´t strong...
I had my machine serviced and... Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
