Question about LG 42PC3D 42 in. Plasma Television
When i I am watching T.V the t,v just shuts off,,, n there is no timer on. then when i try to turn it on, it goes on and shuts off. I can do this 20 times. finally it comes on and then after 30 to 60 minutes it shuts off!!!
    Scholar:
  • 120 Answers
Your power supply board is failing, is common for this model
Part # for the power supply should be YPSU-J011A
The cost of a used board on-line is around $125 you should be able to have it repaired for around 200-250 locally but it would not be recomended as a failing power supply will but additional wear on other components, If you plan to repair you should stop using untill it is fixed so as not to put wear or cause damage to other components in the TV
Posted on Sep 14, 2010
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
How do you shut down Intermatic T104-20
Override timer by removing trippers.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Turn timer OFF by turning off circuit breaker.
Troubleshoot intermatic timers:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 13, 2012 | Intermatic T104-20 Indoor Hot Water Timer
Tv goes off by it self i turn it back on goes about another 20 mins goes back off
Have you went through your menu options to see if it has a SLEEP TIMER set up? Your SLEEP TIMER may be on. If it is then it will automatically shut down when specified.
Feb 01, 2012 | Televison & Video
On a Paragon 8145-20 Defrost Timer, I know you land the refrigeration circuit on terminal 4, the heater on terminal 3, but what goes on terminal "X" and terminal "N"
Link below has 8145-20 wiring diagram:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Terminal N is 2nd wire needed to complete circuit.
In 240V 8145-20, there are two hot wires.
One Hot connects to terminal 1, with jumper to terminal 2.
Second Hot connects to terminal N, and this will power the clock motor and timer.
Terminal X is for temperature or pressure termination switch.
Defrost cycle works like this:
Timer is running but switched OFF.
Refrigeration fan is ON.
Timer switches ON, defrost cycle begins.
Refrigeration fan turns OFF.
Hot gas defrost turns ON.
When temperature-or-pressure limit switch reaches trip point, it switches timer OFF.
Refrigeration fan turns ON again.
Hot gas defrost turns OFF.
Aug 01, 2010 | Paragon 8145-20 Defrost Timer
No action shutoff was activated. How do I turn
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
May 28, 2010 | Panasonic TH-46PZ800U Plasma TV
Panasonic CT-30WX54 - shut off while watching
The Sleep timer might have got set accidentally. Try that.........
Apr 25, 2009 | Panasonic CT-30WX54 30" TV
Dishwasher just started not filling enough water to wash dishes.
It does sound like a circuit board problem but lets not rush out and pay an exorbitant service fee yet...I checked the user manual and this model does have a timer also...so often timer go out and many people think the problem lies elsewhere...but when a timer goes out or a couple of teeth no longer engage then you could have any number of problems...I doubt the solenoid is bad or it would not initiate at all to begin with,,,,,so here is a little test......turn the DW on and cycle the timer to where it starts the water solenoid....watch the timer to see that it turns and disengages. the solenoid...How quick was it? (if under your accustomed 2 mins... problem with timer). Another test is to do the same and hold the timer tightly preventing it from turning and see if you can force the fill valve to stay open longer (if so...bad timer).
I hope this helps...please rate me....The Fang
Mar 12, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
Jan 09, 2009 | JVC HD-61G787 61" Television
Need help asap, please!
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
LG 42PC3D 42 in. Plasma Television Logo
117 people viewed this question
