Question about Mabis Health & Beauty
My bp monitor 04-203-001. Inflation bulb doesn't inflate after I squeeze it, fast enough to build up enough pressure for a reading. Bad release valve maybe. Need cheap fix..
  • 944 Answers
The valve is the problem.The valve release the pressure quickly so when you squeeze it gets released.You have to just take apart the valve.There is no need for change of valve.Keep some thin paper at the tip of the valve screw and turn the valve.Check the bulb is properly closed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 14, 2010
What's causing air inflation problem?
then contact the company for a replacement
Jun 30, 2015 | Braun Bp-5900 Exactfit Plus Bp Monitor
What is a blood pressure monitor?
monitors a machine that you apply a wrist strap sensor to your arm and allow it to inflate. This will cause a build up a blood from circulating then it releases the inflation in the strap in which it gives you a calculation!
Jul 25, 2012 | Exercise & Fitness
Insturctione how to use omronHEM432CN2
Taking your blood pressure is easy with the lightweight and convenient Omron HEM432C blood pressure monitor. Simply wrap the cuff around your arm and squeeze the bulb to begin inflation. In seconds, your blood pressure and pulse readings are displayed on the large digital panel. The Omron HEM432C has been tested, evaluated and proven to meet the rigorous safety and accuracy standards set by independent organizations.
Dec 05, 2011 | Omron Healthcare Omron Hem432cn2...
When I'm pumping it up the ball sticks and will not inflate. I hear air coming out from the ball you squeeze.
If this is happening when the finger valve is closed, there is a leak either in the rubber tubing or the inflation bulb. Try putting soapy water on the tubing and then on the bulb. Squeeze the bulb with just your thumb and forefinger, so that you can see any air bubbles. If the leak is in the rubber tubing, you may be able to repair it with a couple of laps of vinyl tape. If the bulb is leaking, that will have to be replaced.
Hope this helps you solve the problem.
Mar 18, 2011 | Health & Beauty
The cuff squeezes my arm too much and it hurts. The reading is way too high everytime. I don't know how to adjust it.
do not inflate the cuff too much. if you know your usual blood pressure, just add about 5-10 mmHg when you inflate it so that you won't hurt yourself. for example, if your BP is usually 130/90, squeeze the cuff to 135-140 only. but if you doubt that your BP is way much higher than that by assessing on what you are feeling, just do not squeeze the cuff further than 200.
Jan 21, 2011 | Life Fitness Ultra Blood Pressure Monitor...
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
DOES THE 750 LI 2006 HAVE TIRE PRESSURE MONITORS
It either has Tire Pressure Monitor (TPM), or Flat Tire Monitor (FTM)
TPM:Checks the tire inflation pressure in the four mounted tires. The system indicates if the tire inflation pressure has dropped considerably in one or several tires.
FTM:Keeps track of the inflation pressures in the four mounted tires as you drive. The system triggers an alert whenever the inflation pressure drops significantly in relation to the pressure in another tire.
Aug 18, 2010 | 2006 BMW 750Li
Where is omron bp monitor service center in india my bp monitor doesnot get enough preesure and shows no 50 on the screen.
call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
Jan 19, 2010 | Omron Automatic Blood Pressure Monitor...
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Health & Beauty Logo
258 people viewed this question
Top Mabis Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Dan Webster
Dan Webster
Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
