Question about Epson Stylus CX3200 All-In-One InkJet Printer
My daughters all in one printer says its printing, and then that the job is completed, but nothing has happened. She has a P C.
    Problem Solver:
  • 17 Answers
Does it make any sounds as the printing is supposedly being done? There should be some kind of sound as it tries to pick up the paper and push it through.
Posted on Sep 19, 2010
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Nov 29, 2012 | HP LaserJet 4300 Printer
Print jobs are completed with no problems sometimes, other times the print queue shows the job being printed, but nothing happens. Printer status shows "offline", but if I click on the...
Reason behind "offline" is communication between printer & system got interrupted,check weather printer is restarting it self ? check with another USB cable,check firm ware if low version up load it, check printer USB port on formatter is it dry solder? if no check the voltage in connector 17, between pin 1 & 20 is it 5V? if not check power supply connector J201 pin1, is it 5V? if not replace Power supply PCA.
If 5V showing between pin 1& 20 replace formatter.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
Won't print, no error messages. no indication anything is wrong, ready light is on, but nothing happens. If I go to printer menu, it says jobs stopped. When I hit start jobs, it says waiting for printer......
Go into the printer menu and try to print the configuration page. If it doesn't, remove the network or USB cable and try again. If the configuration pages print, see if you can print the event log. That has a reasonable explanation of what is happening.
If you can print the config and event logs, there is nothing wrong with the printer. Delete the printer from your PC and reinstall the drivers.
Oct 30, 2010 | HP LaserJet 3600n Printer
7310 wont print
u have to clear the sent job, go to printers and faxes through your start menu, if u cant find it there, go to control panel, double click on the printer and faxes icon, on the pop up window, double click to open the printer then select all the jobs and empty the box, then you can start using again, make sure the printer is off while doing that.
Jul 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I send a print job to the printer and nothing happens
try downloading the latest print driver from www.kyocera.com or www.mita.com you may have a corrupt driver or it may be incompatable with an update
Jun 11, 2009 | Office Equipment & Supplies
I click print and nothing happens.
go into your print que and see if there is a job prior to current print job that did not print... highlight the prior job and right click, scroll to delete and after you delete prior print job, job and printer should start up
Jun 05, 2008 | Office Equipment & Supplies
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Printer not printing
double check that USB is fully seated on both ends.
OR
make sure that (if IR remote) have the same settings and address'.
Mar 29, 2008 | Epson Stylus 880 InkJet Color Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
