Question about Interlink ePad-ink Pro (VP9862) Touch Pad
The light is low so you can't see as you are signing. Can it be opened and the bulb changed?
    President:
  • 2,777 Answers
It can be repaired, but I wouldn't recommend you try to do it yourself. Interlink can definitely fix this system, but you will need to contact them directly. I would recommend just calling them at 1(800)520-3464 or email their support directly at support@epadlink.com
Posted on Sep 14, 2010
Low beam not working
I would look at the headlight switch test the switch at the connector for continuity and or voltage.Always look at the simple and easiest areas first, bulbs, fuses, relays, then the wiring to the switches, then the switch.
Feb 17, 2015 | 2002 Kia Sedona
How to change the low beam light bulb on a 1995 chevy pickup truck?
the light bulb will be located at the back of the light houseing some low and high beams r in the same bulb
Sep 06, 2014 | 1995 Chevy 1500 Pickup Truck Grill with...
2004 jeep grand cherokee driverside head lamp- low beam bulb needs to be replaced. How is this task performed?
That does not look like a low beam lsamp. It looks like a parking and turn signal lamp. The low and high beams are together in the main top light. To change the parking light bulb open your hood and look behind the light system for a cover over the bulbs. That should be where you can yurn out a plastic fitting that houses the bulb.
Jan 02, 2013 | Cars & Trucks
The brake light indicator light is on even after changing bulbs. What else will cause the warning light please?
Check your brake fluid, there is a level sensor in the brake fluid reservoir, if the fluid is low it's usually a sign that you should check your brake pads/shoes for wear, if the pads and shoes are ok, then top off the brake fluid and keep an eye on it for leaks (just make sure it doesn't get low again quickly).
Jul 09, 2010 | Cars & Trucks
How do i change the low beam headlights on 99 porsche boxster
open the bonet remove back of light after clearly identifying the low beam bulbs, simply pull out and replace with the correct bulb.
WARNING: do not use incorrect bulb as you then risk a more extensive electrical problem. make sure you find out the correct bulb for your car and order from a specialist.
Nov 24, 2009 | 1999 Porsche Boxster
Low beam lights will not turn on
did you pull out the bulb and check it? it is possible that moisture got inside the connection b/w bulb and connecting plug/harness. which it is possible that moisture fouled the low beam circuit and not affect the high beam. (this happened to me) inspect for signs of moisture in the headlight lens and around the wiring. purchase new bulb,install new bulb turn on lights
Apr 02, 2009 | 1997 Dodge Ram 1500 Club Cab
Low beam not work !!
replace the headlight bulbs. Usually when the bulbs blow out the low beam blows out first, but the high beams still work. If you want and need both low and high beams to work then replace the headlight bulbs with brand new ones and I garauntee that both low and high beams will work
Mar 27, 2009 | 1999 Dodge Caravan
2008 gmc acadia low beam light bulb changing
how do you change the low beam light bulb on the 2008 gmc acadia
Feb 24, 2009 | 2007 GMC Acadia SLE
Low beam headlight
Just change the bulb, open the hood you will see the connector to the bulb, most are a twist lock to release the bulb from the head light lens.
Sep 10, 2008 | 1997 Jaguar XK8
Interlink ePad-ink Pro (VP9862) Touch Pad Logo
48 people viewed this question
Top Interlink Computers & Internet Experts
David Payne
David Payne
Are you an Interlink Computer and Internet Expert? Answer questions, earn points and help others
