Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
The water line was frozen (no ice being made and no water available in the door), so I took everything out of the fridge and freezer, let it all defrost, plugged it back in, now I have water in the door, but it still is not making ice and the green light near the button in the back of the freezer is blinking..... how can I fix this?
Grab a blow dryer and aim it at the water tube that supplies water to your ice maker. More then likely it is frozen with ice and will need further melting to clear it out so that your ice maker will work again
Posted on Sep 14, 2010
Hi,I have frig GE Model : psw26msta ,problem is no making ice,I was replace filter ,water out from the door is working good,freezer work good, only making no ice,please help me how to fix ,Thanks my E mail is tranvanluan@aol.com
Posted on Jan 05, 2011
2 Suggested Answers
  • 111 Answers
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
Posted on Jun 17, 2009
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Wont make ice and frozen water running down door
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice maker won't work
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The machine water pressure is low cheak the inlet water pressure and cheak the machine water in let line any block
Jun 21, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
No water to door
Did you change any settings resently or move the fridge? Water line could be kinked. Could be a frozen water line. If the ice maker is set on rapid ice, turn it off. You could turn the temp setting down for a day to see if that helps. Do you have any leaks behind or under the fridge? Check the filter again, make sure you pulled the shipping tag off and that it is seated properly. Freezer temp could be set too cold. Make sure the freezer door closes properly and that there isn't anything hendering it.
Jul 07, 2007 | Kenmore 56722 / 56724 / 56726 / 56729
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
1,023 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
