Question about Mtd 22" Yard Machine Push Mower
I have a poulan pro mower with Briggs and Stratton motor, neighbor used and hit trunk stub from old bushes, now cannot get started again
    Problem Solver:
  • 13 Answers
Probably sheared the flywheel key. pull top off the engine and check to see if key is sheared
Posted on Nov 18, 2012
    President:
  • Mtd Master
  • 1,545 Answers
Most likely, the flywheel key has been sheared. This tiny piece of aluminum metal breaks to save the motor from doing the same when this happens. Remove the top engine cover. Then remove the starter/recoil unit . You should now see the flywheel. There is a slot in the crankshaft that lines up with a slot in the inside of the flywheel. The key goes between the two, you will be able to see that it is sheared if the notch in the flywheel slot isn't lined up with the crank slot. IF it isn't...key has sheared and now the engine timing is off..so it won't start. This isn't the end of the world. You will have to pull the flywheel off ...remove all parts of the sheared key...and install another one (99 cent part).
Posted on Sep 14, 2010
Hit a stump with lawnmower, now wont start
You may have sheared the flywheel key. This throws the timing off. If the shaft isn't bent replace the key.
Jun 22, 2014 | Poulan Pro 22inch 625 Series Briggs ...
My poulan pro 550 series is vibrating a lot when I started. And the front wheel drive is not working anymore.
you need to unplug the spark plug then turn the mower on its side sounds like you hit a rock and bent something and if you bent the crank the belt might have fallen off
Jul 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I have a Poulan Pro - Briggs/Stratton 6.25. It ran really well and when i added oil (starting to think the wrong kind - sae 10w30 from gas station) it has continued to blow white smoke and then it sort of...
Yes,but do not drain it all off.It sounds like there may be too much oil in it.Drain some of the oil and start it again to see if that fixes the smoke.30 wt oil is ok to use in your mower.
Jun 18, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a poulan pro 550 Briggs and Stratton Lawn Mower. I need to find theOil Realease Button
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Sep 24, 2010 | Poulan "Poulan" Push Mower
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
Mtd 22" Yard Machine Push Mower Logo
122 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
