Question about Toro Lawn Mower With Toro Power Tools
My Toro self propelled mower is only sparking at the plug once in a while like every ten pulls...Could the coil be bad?
    Problem Solver:
  • 9 Answers
Its possible the wire going to the plug is broken inside and lead to the armature-magneto or/and flywheel is dirty
Posted on Sep 15, 2010
Model 20199 used once and will not restart.
Did you take the spark plug out and touch it to a bolt head while pulling the cord? if you did you should see a small spark jump between the plug center electrode and the ground electrode. if you do not see a spark you either have a short in the plug wire or the coil is faulty.
Jul 18, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
I have a toro self propelled 22
There should be a smaller black wire that connects to a tab on the coil, this is the kill wire. disconnect it and check again for spark. To check the coil with an ohm meter: connect one lead to the steel core of the coil, this is the part that is closest the flywheel. Connect the other lead to the tab that the smaller wire connects to. You should get a very low reading of about 0.5 - 1.5ohms. Next move the lead from the tab to the conductor in the spark plug boot. Here you should get around
2.5kohms - 5kohms
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_a3dac712db4ca1a6
Jul 25, 2012 | Toro Garden
Toro 6.5 HP Self propelled walk behind 22
take the top cover off the engine. you will see the coil on top there. unplug the wire that plugs into it. put the cover back on and try to start it. if it starts it is not the coil. try a different spark plug first. pull the cord with the plug out to get all the gas out of the engine.
Mar 20, 2017 | Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
150 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
