Question about Humax DRT400 TiVo 40-Hours Video Recorder
Humax Tivo Recorder
The dvd burner will function correctly until it gets to approximately 40% complete, and then it displays a Failure message. I've tried different disks, and different shows, but it's happening everytime now.
  • judiammar Mar 07, 2009
    I can I correct the "internal error" message that I continue to get when I try to burn a recorded program onto a DVD?
  • 423 Answers
Power cycle the unit. See if the works.
Posted on Feb 15, 2009
DRT400 TiVo 40-Hours Video Recorder: unable to delete programmes...
Do a complete CLEAR and ERASE.
This should fix the problem.
May 18, 2010 | Humax DRT400 TiVo 40-Hours Video Recorder
Cannot get dvd recorder drive to read dvd-rw
manual should tell you to use either dvd(+)rw or dvd(-)rw typ disks
Feb 07, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Can I use HUMAX like a 24 hour surveillance recorder?
For the TIVO series 2: hit the TIVO button, then go to messages and settings, then to to video input, then go to change input, then pick which input your camera uses. It will ask you if you can see the picture. If you can click the answer and then hit the select button. Then hit the TIVO button again then hit watch live tv.
The Humex should work very similar.
Sep 10, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Humax DRT400 Tivo won't burn content to DVDs
My solution is going to require entering the unit, so you may want a qualified service tech to perform the job, but i would check the connection between the burner and the board.
Aug 21, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
No picture on Humax DRT400
Try taking the cover off and taking an air compressor and blowing it out real good. I have the exact same one and I had the exact same problem and after i blew it out it worked like new.
Jan 24, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
Recorder just keeps recycling the boot-up process
It's most likely your hard drive. It has to be functional for the DVD portion to work. It can be replaced by a preconfigured kit or buy a new drive and do it yourself. You can also send it to places like CCS in Indiana that will thoroughly test out the unit and give you options.
Dec 24, 2007 | Humax DRT400 TiVo 40-Hours Video Recorder
Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
www.funai.us
Customer Support Representatives may also be reached by telephone at 800-242-7158
Oct 28, 2007 | TruTech TT1620 DVD Recorder
The dvd tray is jammed (due to child input)
If you can carefully take top off of unit you can possibly find out what is jamming tray. If removed may operate correctly.
Aug 19, 2007 | Humax DRT400 TiVo 40-Hours Video Recorder
Humax DRT400 TiVo 40-Hours Video Recorder Logo
148 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
