Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
How to install an ikea cabinet door on a fully integrated Bosch 25 inch dishwasher
5 Suggested Answers
textonor
  • 130 Answers
SOURCE: Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Posted on Jan 06, 2008
  • 9 Answers
SOURCE: I have a fully integrated
hi casey
with my experience with d/w i found that if you pull apart the inside were the blades are there are round plates that require cleaning and there might be something under the plates.goodluck
Posted on Jun 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Bosch Dishwasher SHU43C Not Washing Dishes
Check for plugged nozzles
Posted on Feb 08, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Bosch Dishwasher Model SHU66C soap door will not open
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
Posted on Jun 06, 2010
Bosch dishwasher trips power supply when door fully opened after cycle completes
The dishwasher will have a wiring harness which passes through one of the corners or in the centre of the door. I would suggest that the harness has perished or weakened and exposed a live wire which touches the cabinet when the door is opened and it shorts out. Opening and closing the door after many years of use weakens the wires where they get continually bent back and forth during door opening and closing. Ive seen wires rejoined but the only sure fix is the replace the wiring harness.
Feb 23, 2015 | Bosch Dishwashers
Dishwasher do not start up
Most likely the door is not shut properly or the door latch switch is faulty. I will assume the water is turned on and the power is connected. Also check the delay start is not programmed.
Sep 14, 2014 | Bosch SHX68P05UC - Integra 800 Series 24"...
Bosch custom panel dishwasher
Use the add image function here to attach a picture of your installation
Mar 17, 2014 | Dishwashers
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
I have a Fisher and Paykel drawer dishwasher and I'm wondering if there's a way to put a panel on it to make it look like and integrated dishwasher. It would need some way of the panel moving to start the...
hmmmm...the first thing that comes to mind is to check out ApplianceArt.com. they have alot of panel options. I'm not sure if they have the integrated ones you are looking for but they have cheap options for everything else.
Nov 19, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Dishwasher
Hello Booklice,
Normally a standard base cabinet is 24 inches deep with a 25 inch countertop ( meaning the top extends over the front of the cabinet by 1 inch) That is a typical installtion however there is no right or wrong way to set the dishwasher into cavity between two cabinets. In most installations though the front door of the dishwasher when closed is close to flush with the vertical stiles of the cabinet and does not extend beyond the overhang of the counter. The manufactures method for securing it to the surrounding cabinets will dictate the extent that it can project out. Hope that helps...
Regards
Oct 05, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Feb 28, 2008 | Dishwashers
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
148 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
