Question about Pride Mobility Products Hurricane PMV 4-Wheel w/55AH Batteries & Charger + Flat Free Tires - Color Viper Blue - Gray Fabric Seat
My dad has a pride legend and the motor gets hot and stops working. I removed the motor and took to a motor rewind place but it tests out perfect. The transaxle seems ok and now I am wondering about the brake. The motor starts to get hot there and around the brushes but the brushes are in good condition. Any ideas would be appreciated.
  • 692 Answers
Cody yep that could be the problem. When you engage the throttle do you hear a click from the electric brake? Its possible that the brake pad is stuck to the motor casing and causing friction thereby creating the heat you feel. Now you can't just remove the brake cause the controller looks for it to let the scooter move. You can however take the brake assemblt off the motor and tie it to the frame and see if that sloves the problem Be careful not to break the wiring to the brake. If that works and dad doesn't use any ramps (He won't have any brakes to stop him on an incline) Then he can use the scooter like that until you can replace the brake. He must be careful cause only the motor will stop his forward progress when he releases the throttle. Did Medicare buy his scooter? If so contact a provider or a service company and Medicare will pay for most of the repair. Hope this helps you
Posted on Sep 14, 2010
Why won't my pride legend start?
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Sep 03, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Pride Legend Seems to Overheat?
hi, could be your brake dragging ? (located on the side of the motor) touch this with care =after using the scooter is it hot ? Are your sure a wheel not rubbing against bodywork ? ,
Regards
Rob
www.gewizrepairs.co.uk
Jan 26, 2014 | Pride Health & Beauty
I need a wiring diagram for a 2001 Legend Pride Mobile
Me too. Any luck, have the same year three wheeler only getting 6volts at motor.
Local dealer is a joke, wants to overhaul entire unit before fixing the trouble.
Jun 24, 2011 | Electric Mobility Pride Legend 3 Whl ...
I have a legend pride four wheel electric scooter. It does not run anymore. We checked the batteries and they are good and we charged them. We also went through all of the wiring and made sure the...
Hi. Is the machine display any fault codes, ( flashing battery light)? Is the free-wheel lever in the correct place, Move it in and back again and try it. It is possible that you have a stuck brush in the motor. Get a multi meter and check the resistance through the motor. Check that the brake unit is releasing properly.
If one of the battery lights is flashing, count the flashes and let us know what the pattern is, and we can tell you what it means. Good luck. Neil.
May 09, 2010 | Pride Mobility Products Pride Legend XL -...
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
I have a pride legend classic xl8 and the spline drive from the motor to the diff has snapped, where can i get a new one or do i have to get a new rear axle complete?
hi, can you send me a picture of this so I can assess the damage, I have repaired many gearboxes so it not a problem.
helpNOSPAM@gewizrepairs.co.uk
just remove the NOSPAM from the emaill adress so it correct.
Regards
GeWiz.
Dec 10, 2009 | Pride New Mobility Legend 4 Wheel Scooter
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Oct 19, 2009 | Pride Mobility Products Pride Legend XL -...
Old BEC Stirling 4. just stopped!
There will definitely be a fuse or thermal cut-out (or two) for the batteries, but those must be OK. Double check wiring to the motor? Was motor or controller very hot?
Aug 30, 2009 | Pride New Mobility Legend 4 Wheel Scooter
My jet ultra 3 powerchair only goes in a circle. i think that the motor is bad or is just stuck. how do i get directions on how to take apart the motor myself.
If the motor is "bad", the chair will not go anywhere at all, and you would be getting a flash code on the joystick control indicating a left or right motor fault.
There are levers for each motor that allows the motors to be placed in neutral to manually roll the chair. Disengage and re-engage both levers to the drive position and now go in a straight line. You probably knocked one of the levers partially out of drive.
There's nothing in the motor case that you can service, beside the bearings on each end, and those would not cause a motor failure that you describe, and you can hear them whining long before they ****-out.
Motor failures are cause by overheating a motor, which in turn, opens up one of the copper wire windings, of which, there's several hundred feet wound around the armature, and then they are all lacquered together. A motor rewind shop would remove this ball of copper wiring, and rewind the motor and replace the brushes and bearings for about $250.00.
You should download an owners manual at Pride Mobility's website. Good luck.
Jul 08, 2009 | Pride Mobility Products New Pride Mobility...
Pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Apr 24, 2009 | Drive Medical Mini Phantom Three Wheel...
Pride Mobility Products Hurricane PMV 4-Wheel w/55AH Batteries & Charger + Flat Free Tires - Color Viper Blue - Gray Fabric Seat Logo
277 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
