How to generate random numbers on casio fx-83es
  • 449 Answers
Use the random number function, RAN#
Manual: http://support.casio.com/pdf/004/fx-82ES_83ES.etc_Eng.pdf
Posted on Mar 25, 2011
How do i change from getting answers in fractions to decimals on a casio fx-83ES?
Change the Input/Output Mode to LineIO. Press [SHIFT][MODE] and select [2:LineIO].
Aug 07, 2011 | Casio fx-300ES Calculator
How do I generate a random number that is greater than 1 on a casio fx-300MS
The random number function always generates a number between zero and one. You can convert this to a random number in any range by a suitable combination of multiplications and additions. For example, if you want a random number between zero and ten, multiply the generated random number by 10. If you want a random number between one and ten, multiply the generated random number by 9 and then add 1.
If you want to simulate the roll of a six-sided die, multiply the generated random number by 6, add 1, and ignore the fractional portion. This will give you a 1, 2, 3, 4, 5, or 6 with more-or-less equal probability.
Mar 10, 2011 | Casio FX-300MS Calculator
How do i convert 45degrees into radians on my casio fx-83es calculator?
To convert from radians to degrees, multiply by pi and divide by 180.
Feb 19, 2011 | Casio FX-115ES Scientific Calculator
How to use the random number generator on the calculator.
To access the Random number generator, press [MENU], Use arrows to select [RUN] and press [EXE].
In [RUN] press [OPTN][F6:->] to pan to the right then press [F3:PROB] then [F4:RAND#]. The command echoes on the screen.
  1. Now if you press [EXE] a number between 0 and 1 is generated.
  2. Each time you press [EXE] a new number is generated.
Although it is not documented, I found out that if you enter RAND#(n) where n is an integer, it generates a number between (0 and n)
Hope it helps.
Nov 07, 2009 | Casio FX-9750GPlus Calculator
CASIO fx-83es
Press [SHIFT][AC] (ON).
Hope it helps.
Oct 20, 2009 | Casio fx-300ES Calculator
I am having trouble simplifying ratios on the FX-83ES. Any ideas? For example 10:5 should come up with 2:1, but it comes up with 10 when I press =.
am having trouble simplifying... Solve I am having trouble simplifying ratios on the FX-83ES. Any ideas? For example 10:5 should come up... (More) I am having trouble simplifying ratios on the FX-83ES. Any ideas? For example 10:5 should come up with 2:1, but it comes up with 10 when I press =.
Sep 13, 2009 | Casio FX-300MS Calculator
How do i input the radian symbol
Multiply it by 180 and then divide by PI.
Feb 23, 2009 | Casio fx-300ES Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Casio fx-83ES
Press Shift and then In
Dec 08, 2008 | Casio fx-300ES Calculator
689 people viewed this question
k24674
