Question about Singer 5050 Mechanical Sewing Machine
Need Bobbin & Bobbin Case for Singer 5050C Sewing Machine
    Genius:
  • 1,788 Answers
Go to www.sewingpartsonline.com and order one from there.
Posted on Sep 14, 2010
5050c bobbin wont wind
The pickup wheel under the bobbin stem may be worn and needing to be replaced (assuming it has not been knocked and bent off line) .
Try using a pen to push the bobbin stem further over when you are trying to wind it. If it starts to spin, then this is probably the answer.
Jul 13, 2016 | Singer 5050 Mechanical Sewing Machine
I have a 2013 Singer one plus that I bought less than a year ago. My bobbin case keeps locking up. After I take plate off & take out bobbin case then put back in correct position & sta
Could be that your bobbin thread is wound too tightly and having a problem pulling thread from it. Try setting the pressure on bobbin a bit less and that may cure it.
Sep 30, 2014 | Singer One Plus Computerized Sewing...
Singer 5050c when I move the bobbin shaft to engage to fill the bobbin it won't engae
That usually means the clutch or belt is worn out, and it's not worth fixing. You can buy an inexpensive bobbin winder for under $25.00 at WalMart online, and if you pick it up at a WalMart or FedEx facility like Kinkos, shipping is free. Does a better job anyway!
Jun 11, 2014 | Singer 5050 Mechanical Sewing Machine
I think the plastic on the bobbin case has been chipped off a bit. Can't get it to stay in place. I believe I've got it in right, it just won't stay there. After taking it out and looking at...
I think this is your bobbin case
http://www.sewingpartsonline.com/bobbin-case-apollo-singer-421326.aspx
being plastic they are damagable if the case moves and the needle strikes it. Sometimes you can file out the damage with a nail file. But replacements are available too.
Hope this helps.
Oct 10, 2011 | Singer 5050 Mechanical Sewing Machine
I have a 5050c singer The bobbin case jump out and now the needle hits on the metal plate that is under the bobbin case. How do I fix this ?
I think that you have had the wrong size bobbin. It should be a class 66. Look in your manual, it should tell you. If, that is not it, call Singer at 1-800-4singer and ask if it sounds like the timing and if so where can you take it to get fixed. This is a nice machine, my friend, has one and it is worth getting fixed if you like it.
Jan 01, 2011 | Singer 5050 Mechanical Sewing Machine
How do i fix a birdnesting problem with my singer 5050c sewing machine , or do you have instructions of how to thread the machine.
Try adjusting the tension. It sounds like the bobbin thread is too loose or the bobbin is not in correctly. Try taking the bobbin out and turning it around and putting it back. When you hold the bobbin in the fingers of your left hand and you pull the thread out with your right hand the bobbin should be turning clockwise. If the nesting persists, try ajusting the tension one way and then the other to see which seems to help. Hope this helps!
Jun 01, 2010 | Singer 5050 Mechanical Sewing Machine
Bobbin issues
Take out your bobbin case... there should be a small screw fixture on the side of the case...turn screw anti clockwise until you get the correct tension ... To test the bobbin thread tension...Remove the bobbin case keeping bobbin attached and hold it by suspending it by the thread...**** it once or twice, if the tension is correct the thread will unwind by about an inch or two. If it does not unwind at all...tension is too tight. If the tension is too loose it will drop too much. Goog Luck
Jun 01, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
57 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
