Question about Kenmore 22422 Top Load Washer
I have a Kenmore issue
First we can't open the lid. 2nd the button that activates the machine is broken. We are trying to open the machine to look into this problem. Any ideas? The model number says 24632300
    President:
  • 1,314 Answers
Get a putty knife and come over about 2inches from the front edge and push in between the top and cabnit should feel a spring retract at the same time your lifting the lid do the otherside and raise the top the push the hook back on the latch and raise the lid then replace the lid lock switch
Posted on May 16, 2008
How do I replace the switch lid on my top loading Kenmore 80 series washing machine
first you have to figure out if the lid switch is the problem, it may not be.
2nd you should really get a repairman to fix your unit.. it takes experience just to open the covers.
Please rate/vote this response thanks
Dec 19, 2010 | Kenmore 24032\24036 Top Load Washer
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite not spinning
This issue is caused by:
- Lid open. Be sure the lid is correctly closed
- Lid switch broken. It may need to be replaced.
- Motor broken. QUite expensive repair, the motor needs to be replaced.
- Timer broken.
Check the lid is correctly closed, perhaps the lid switch is having some failures.
Nov 05, 2009 | Kenmore Washing Machines
Won't run after it fills up either small or lg. load.Just stops.
check the lid switch . unit will not work if the lid switch is not activated it's probably broken.
Jan 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer will do everyything but final rinse
This is a very typical symptom of a lid switch that is either broken or has come loose. If your lid switch is mounted on the right hand side of the lid, make sure the mounting screws are tight and the lid strike is in place (this is a plastic piece on the lid that activates the switch when closed). If your lid switch is on the left hand side in the rear under the washer rim (out of view), you may have to adjust the rod that activates it. For instructions on how to access the lid switch and/or replace it, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you need further assistance, please post back and let me know. You can also go to my profile and use the "Ask Me" feature for a quicker response.
May 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working.
On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $25 and is fairly simple to replace if you follow the steps below:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
You can find a replacement at searspartsdirect.com. If you need further assistance, please post back and let me know.
May 10, 2008 | Washing Machines
Not spinning
I am assuming that you washer is agitating, right? If it is...and, your symptoms are: normal fill, agitate, but when it gets ready to spin, the washer stops - this is usually a symptom of a defective lid switch. Try opening and closing the washer lid, you should hear a distinctive clicking noise as the lid closes. This will activate the lid switch, which will control the timer and all other functions. The lid switches come in two basic types for Kenmore:
1. It will be located on the right-hand side of the lid opening as a small slot with a plunger from the lid activating it as it closes.
2. It will be located on the left-hand side of the lid opening in the back with a rod on the lid hinge activating the switch.
This is a fairly common problem that can be easily fixed. The switch usually costs about $35.
If this sounds like the symptoms you are having, let me know and I can determine what part number you might need, and give you advice on how to fix it.
If not, please post back with comments and elaborate in a little more detail. I hope this helps you.
Jan 31, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 22422 Top Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
