Question about Samsung CLP-600N Laser Printer
I just replaced the cyan cartridge and I get 4 blue lines that print where they should not be. If I print a blue picture - those line tend to be a lighter blue. I have taken the cartridge out and replaced it with the empty cyan one and no blue lines print. When I put the new one back in, the same thing occurs.
  • 1,110 Answers
Obviously you need to return the Cyan cartridge to where you got it. It is bad. Is it OEM Samsung or is it remanufactured. If it is remanufactured then it will usually say "for use in" or "remanufactured" somewhere on the box.
Either way it sounds like you need a replacement cartridge under warranty.
Posted on Sep 14, 2010
Testimonial: "Thanks"
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
Why too much yellow and red no greens or blues ?
Inkjet printers use additive pigments. CMYK, Cyan, Magenta, Yellow and Black. It sounds like you're not getting any Cyan ink to the paper. Either your printer is out of Cyan ink, or your Cyan print head is clogged.
Go into your printer's Properties and run a Nozzle Check. It will print a series of lines with each color. There will probably be a big empty space where it tried and failed to print Cyan. You can try cleaning the print heads, but if you're getting NO Cyan that is unlikely to work.
If you're lucky, your printer is one of the ones that the print heads are built into the ink cartridge so replacing the cartridge will resolve the problem. If you're not, you might need to get it serviced (or probably more cost effective, buy a new printer).
Apr 30, 2014 | Epson Stylus CX5700F All-In-One InkJet...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
After every line of black text there is a light blue line.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 01, 2010 | Epson Stylus CX3200 All-In-One InkJet...
I have a Stylus CX5400 and can't get black to print without mixing blue into it. Tried new cartridges, same effect. On a text document the same lines turn blue everytime I print, the rest prints black. Any...
You may have a leaky blue (cyan) cartridge that has polluted the black output.
Well worth checking the inside of the printhead (where the cartridges are located) and see if there's a build up of ink.
Also, well worth checking that you haven't received an incorrectly marked cartridge that contains cyan instead of black ink.
May not be the direct solution but it will certainly help isolate a few possible causes.
Hope it helps.
Martin
Oct 01, 2009 | Epson Office Equipment & Supplies
My HP 2840 is printing blue lines on the side of the page
3 Causes for printing Blue Lines on the side of the pages.
01. If it happens with test pages from the machine itself as well as docs;then most likely it is a bad cyan cartridge.if you open the drum shutter on the cyan cartridge,can you see a line on the drum?
02. If the Drum is opened and you can see a continuous line of blue toner is at both sides of the drum. Chance of getting blue lines printed on the side of the pages.
03. If the cartridge is leaking then and will need to be changed.thats why it's ending up on the belt also and it prints blue line on the side of the pages.
Aug 06, 2009 | HP LaserJet 2840 Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Drum issue
Try another cyan toner cartridge, If you are using compatiables it my be defective.
Jan 30, 2008 | Canon imageRUNNER C3220 Color Copier
Samsung CLP-600N Laser Printer Logo
476 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
