posted by eco953 on May 16, 2008
ok when i start uo my labtop it loads then says unsafe shutdown and list choices safe mode safe mode with network safemode with command prompt start with last known config that worked and start normaly. heres where it gets wierd ive tried every option and it loads upto the windows xp service pack 2 btw and then quickly flashes a blue screen then restarts and i cant get it to stop its been going on for days every time i try same thing cant run system req i think never figured out how to.... but if any 1 at all can help plz do thank you.
Comment by eco953, posted on May 16, 2008
my email is eco953@gmail.com thank you very much if you can solve this
Best Solution
Hi eco953,
I just recently faced the same problem.What I did was I boot up with my original Windows CD that do have repair option.After that if you're repair mode run CHKDSK /R ,this will check your harddrive and repair BAD sector.I didn't realise that I have a bad harddrive and when it read up to that sector it just crash and blue screen POP-UP.
Incase you don't have a Windows CD then the other choice is to remove this harddisk out and connect to other PC/Laptop and run software to check Harddisk fist.
Goodluck,takecare
Goodluck,takecare
Rating Locked! (?) eco953 has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Compaq Evo N610C PC Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
battery charging problem
Hi, My laptop battery does not... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
