Where is the filter bung for the siemens WM2400 washing machine. Water is not draining away.
SOURCE: My Bosch Classixx 1400 express
How do I take the Child lock off
Posted on Oct 27, 2008
  • 135 Answers
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Posted on Nov 15, 2008
barkencoa
  • 3463 Answers
SOURCE: the fabric softener drawer is
Remove drawer and thoroughly clean, you must have a blockage in it for the water to remain.
Make sure that you clean every piece of it, taking all the components out.
Please leave feedback.
Posted on Dec 01, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
SOURCE: my bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Posted on Dec 01, 2010
Model EDI97170W code error E20 appear on the LCD panel.. is means for
An Electrolux?
The E20 fault code means there is a blockage in the drainage system of the machine.
Check the drain hose, the laundry sink tub and also the pump filter at the bottom right hand side of the washing machine on the front of the cabinet. Pry the door open, undo the filter bung and clean out the pump housing ok,
One of these is blocked and it is restricting the flow of water when the machine should be fully drained before spinning.
Dec 04, 2016 | Washing Machines
I have a Haier HWD1600 washer dryer combo that I am getting an error 2 on. It will not drain the water out and I have not been able to clear it for the past two months
Its a common error,
Error message:Drain error, water can be not drained fully within the required drain time
Reason 1. Pump filter is blocked.
Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine)
Step 1.Push a flat blade screwdriver into the slot on the filter cover and pull it open ,do not use excessive force.(Fig 1).
Step 2.Remove the rubber hose from its clip and stand a suitable container under it, remove the bung to drain the water (Fig 2-3)
Step 3.Replace the bung and fit it back into its clip (Fig 4-5).
Step 4. Unscrew the filter and rinse it under running water, replace it and close the flap(Fig 6-7-8).
Caution:
1. The filter must be in place during operation, ensure it is in place after cleaning to avoid leakage.
2.Place a container under the drain pump filter, to collect any excess water that may come out of the drain pump when the filter is removed.
Reason 2. Drain hose end is higher than 100cm above the floor level.
Solution 2. Please adjust the height of drain hose to 80-100cm above the floor.
Reason 3. Drain hose is blocked or twisted.
Solution 3. Please check and clean the drain hose for blockage.
Reason 4. Drain hose is too long, or water is back filling from waste water pipes.
Solution 4. Remove any extension to the original drain hose.
Ensure the highest part of the drain hose is nearest the washing machine.Check the waste water pipes in the building are clear of any obstructions and flow freely.
Nov 08, 2015 | Haier Washing Machines
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Siemens washing machine keeps washing
Hi Linda Bailey,
If it keeps washing it could be that it is unable to progress to the Drain or Spin cycle. The likely culprit could be the Drain Pump Filter. To clean the Drain pump filter:
1) Plug the appliance out.
2) Open the small compartment below the door (Either Right or left hand corner) You will see a small pipe and a circular lid with a handle.
3) Drain the water by using the small pipe (Get a bowl for the water!), take of the cap of the hose or use the tap on the pipe on some models.
4) Once all the water is drained, open up the cap (Again.. Keep the bowl close by for spillage) by turning it anti-clockwise. Once off, clean the filter which is found on the cap.
5) stick your fingers into the now open compartment, be sure to clean out any obstructions, and feel if the impeller inside can turn freely.
THATS it! Now re-insert the cap, and close the pipe if open. Plug your machine in and viola!
It should solve your problem.
If not, let me know.
Kind Regards
JEDEMEYER1
Oct 03, 2011 | Siemens WM14S794GB Front Load Washer
I have a siemens washing machine - front load automatic. It is now winter here and it keeps showing that there is an error: F 37. What does this mean? that the water froze? what is the problem?
I Had a F37, thought it might be a frozen pipe problem but the filter was blocked. Turn off at mains. Remove the flap at the front bottom, pull the bung out of the hose to drain it then unscrew the pump cover and remove the obstacle. Seems to have done the trick for me.
Dec 20, 2009 | Siemens WFXD8400UC Front Load Washer
STOPS WORKING ON SPIN CYCLE.
I'm unfamiliar with your exact machine, but on many other similar quality brands it's used to drain the machine in a controlled fashion before unscrewing the filter.
Without it, as soon as the filter is unscrewed the remaining water in the machine will gush out. The tubes fitted to most machines have a simple plastic bung on the end which must be removed to drain and replaced afterwards and the tube is normally long enough to be pulled out to enable drainage into a tray or bowl.
Have a towel handy as even after using the tube to drain down there will always be a small amount of sump water spillage when the filter is removed.
Nov 15, 2009 | LG WM1814CW Front Load Washer
The fabric softener drawer is half full of water which does not drain away, even after the washing machine has finished. The detergent drawer is fine. how can I drain this water away? Kind...
Nov 30, 2008 | Siemens WM5487A Front Load Washer
Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Sep 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Feb 13, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
