Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Garage door opener - Model 139.3985D One of the remote openers won't work - learn etc. Battery is good? New install
    President:
  • 3,197 Answers
Although it is rare to get a remote that doesn't work out of the box it can and does happen. Contact Sears you have a warranty.
Posted on Sep 14, 2010
Remote no longer works for craftsman opener model #139.53674SRT1 and don't have manual to figure out how to reprogram it.
First make sure the battery is good. Locate the smart/learn button on the rear of the motor unit. Press and hold the button on the remote and then press and immediately release the smart/learn button. If the remote still works it will be programmed.
Aug 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears Canada 139.53681B FCC ID hbw1255 I DONT HAVE MANUAL & NEED TO RESET REMOTE TO OPEN DOOR FOR GARAGE. CAN ANYONE HELP? V
You don't normally ever need to reset the remote but.....................
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and hold the button on your remote while you press and immediately release the smart/learn button. If this doesn't work either your remote or the receiver has quit working. Make sure the battery in the remote is good.,
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Cannot reset remote to garage door opener Sears craftsman 139.53681B
If you are sure the battery is good then try to program the remote by holding the button down on the remote and then pressing and immediately releasing the smart/learn button. If this doesn't work and you have another remote that does work then the remote has quit working.
May 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
I reentered the new keypad numbers after pushing learn button and
Your keypad is most likely bad or if it's new it could be the wrong model for your opener.
Sep 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener
I just found the solution for my 'ancient' Sears garage door opener, model # 139.655000, and I figured I'd share it.
There's a separate radio module, wired to the main opener. This module is small, has a short wire/antenna, and plugs directly into an outlet.
There's a manual open/close button on this module (I didn't realize this until I got up on a ladder). This button is also a removable cover; underneath it is a "smart actuate" button -- this is your learn button.
What I did was: unplug the radio module. Pry off the cover. Plug the radio module back in. Hold down the button on the remote. Press the "smart actuate" button. This programmed my remote successfully!
Jul 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
57 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
