Question about Mitsubishi WS-48513 48" Rear Projection Television
How do i hook my XBOX-360 up to this tv and get 1080i resolution? Thanks, Mike
  • Mitsubishi Master
  • 5,481 Answers
You should be able to get 1080i with the Input/DVI port or the component video in ports of the TV. I believe the easiest option will be to set the XBox A/V switch to HDTV and use a component video cable (red, green, blue) from the XBox component out to the TV Component In. (with the audio out going to your TV or speaker system). Turn on the X-box and the My Xbox > System Settings. Then Console Settings > Display and chose the 1080i.
Set the TV Net Command (remote) and the Device settings for the input jack in use (component 1/2). Adjust the A/V menu for the Display before playing long.
Wen you change inputs, you will see a status screen for the settings for the TV input.
I hope this helps.
Posted on Sep 14, 2010
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
Philips 1080i xbox 360 hook up
you need to change the settings on the xbox aswell.
go to your settings menu and change the picture settings to 1080i
Oct 27, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Can't get my TV to go to 1080i
Your tv is either 1080p or not 1080 compliant. Try 720p or you may be forced to keep it at 480
Dec 25, 2007 | Mitsubishi WS-55315 55" Rear Projection...
50PX1D-UC
This tv is capable of working with 1080P. Depending on what you are hooking up to it will depend on if you get that resolution.
Dec 12, 2007 | LG 42PX4DR 42 in. Plasma TV
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Cannot get my tv out of 480
you have to go into the xbox 360 settings and change the output screen resolution to 1080i and also check your tv settings input to receive 1080i also.
Sep 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-48513 48" Rear Projection Television Logo
337 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
