Question about Sony KP-51HW40 51" Rear Projection Television
ICS? Bad ICS ?
  • Sony Master
  • 8,617 Answers
Yes you need to replace both Convergence ICs STK392-560 they are available at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 16, 2008
I adjust the convergance cross but there is only one the moves. how do i get the rest to adjust?
If you are not able to adjust one of the Red, Blue colors you may have an open resistor(s) or one of the convergence ICs is bad.
One of the ICs and a bunch of resistors can also go bad at the same time, and it is recommended to replace both ICs even if only one color circuit is bad.
There are convergence kits which include resistors and two STK392-*** ICs available for certain TV sets.
To do the repair you need either the complete kit or find out which resistors are bad and the 2 big ICs STK392-*** the last *** 3 digits could be 110,120, 150 etc..
You de solder and remove the STK ICs and resistors if they need to be replace, install and solder the new parts, adjust the convergence
Doing this repair can be very difficult in some TVs it all depends on the layout and design of the TV and how hard to get to the convergence circuit. I have seen experienced Technicians making mistakes and even damaging the TV.
I have heard a non TV techs did this kind of repair and due, to the 1000s Volts danger of the high voltage inside the TV I suggest, to hire a TV man to do the repair can go from $200 and up.
I wish you the best..
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
Can't correct my red blue convergence manually or by using factory preset...the unit is 7 years old, is my picture tube bad?
You have bad convergence ICs. There are 2 ICs in the convergence circuit, one is for the Blue the other is for the Red. You can buy 2 ICs for under $40.00. Replacing these ICs require soldering and desoldering skills. Sometime, the resistors in the convergence circuit go bad also. Be very careful, there is a very high voltage in a CRT projection TV the voltage is over 30,000 volts.
Best of Luck
Sabre
Feb 23, 2010 | Philips 60PP9202 60" Rear Projection...
Convergence
Panasonics will usually need the 2.2 ohm 2watt resistors replaced with the ICs , as usually at least one will blow possibly two when the ICs fail. If you didnt replace the resistors you will also most likely need to replace the ICs again as a bad resistor will ruin new ICs usually
Jan 05, 2010 | Televison & Video
MY PROJECTION TV HAVE 3 COLOR SHADED PICTURE.PLEASE GIVE TIP AND REPIARING TIP TO RESOLVE THIS PROBLEM
Bad STK ICs Big Black ICs call Mats for ICs 1-800-628-1118 and for whole convergence board Call Zenith moduel Exchange
1-800-632-6637 ICs will have # on them!
Dec 25, 2009 | LG Televison & Video
3d picture and looks like bow tie
Bad STK ICs replace both ICs will have part number on them STK392-110s if this is what you have upgrade to 150s! ICs are Big black ICs also ck 2.7 ohm resistors near ics.
Sep 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Bad color blue green bad pic tried adj covergence no luck
The problem is either poor solder connections on the convergence ICs ore defective ICs. If you can solder, you can fix this yourself. Be aware however, of dangerous high voltages that are present even with the set unplugged. The ICs are STK392-120s and should be attached to a large heatsink. Try resoldering the pins first. If that fails to resolve the problem, replace the ICs.
Dan
Dec 29, 2008 | Philips 60PP9202 60" Rear Projection...
52"rear projection rca hdtv
Yes it is, but that is not the typical solution to your problem. Either the solder joints at the convergence ICs are bad, or the ICs themselves are defective. Try resoldering hte pins on the ICs first. If that fails to resolve your problem replace the ICs. These will be large black ICs attached to a heatsink and marked STKxxx.
Keep us posted.
Dan
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Green and red colors is out of line panasonic pt51hx42
This is a convergence problem. Either there are bad connections on the convergence ICs or the ICs have failed. Try resoldering the pins on the ICs first. If that fails to resolve the problem, replace them, These ICs are large black ICs attached to a heatsink and are most likely marked STKxxx.
Dan
May 27, 2008 | Panasonic Televison & Video
The red and green do not converge on screen. tried auto convergence, does not fix the problem.
There is a problem with the convergence ICs. Either there are bad connections at the pins or the ICs themselves are defective. If you can solder, resolder the pins first. If that does not resolve the problem, replace the ICs. These ICs are large black ICs attached to a heatsink. The should be marked STKxxx.
Dan
May 14, 2008 | Televison & Video
Convergence was bad, and after replacing now a black screen
alot of times the convergence ICs will burn a resistor or one of the pico fuses depending on how bad the ICs were and how long the set ran with the convergence Ics bad. Its fairly common for the resistors to be burned open and they have no outword signs most times other times they may appear slightly discolored
May 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
