Question about Master Heaters B70ET Master
Stored my heater for the summer now wont ignite what do i have to do
  • Master Heaters Master
  • 43,501 Answers
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Posted on Sep 17, 2010
Where to get a copper gas line for Endless Summer 230000 Patio Heater?
Could you use a compression fitting across the break? If you can take a piece of the tubing to local hardware/auto store for sizing to see how snug the brass ring is.
Oct 21, 2014 | Patio Heaters
Water leaking from the housing were the heater eliment is located
the heater core is bad in summer u just route your heater hose's togther where they go thru the fire-wall.put a splice between both hoseses so water wont go into heater-core in winter u need heater u must if u have to use vehicle slow-speed only remove rariator cap pressure then leak wont leak as fast u can use heater until fluid is all leaked out or u can just move heater slide to blue area then water wont be going to heater core it wont leak out as fast or replace heater core
Dec 27, 2011 | Cars & Trucks
My pilot light wont light and my heater will not stay on.The ignitor is cliking as if it works but will not ignite and if I manually light it the lighter will not stay on.
Essentially all gas devices regardless of which gas used, are equipped with a thermocouple that monitors the pilot light's condition and if it fails, it will not permit the main flame to light or the pilot light to stay lit. In your case, it may be that the TC failure also prevents the lighting of the pilot light.
May 20, 2011 | Endless Summer 200209 Open Flame Patio...
Pilot light won't stay lit when I let go of the igniter knob. Flame is yellow and long.
Sounds like the Thermocouple has failed and needs to be replaced. It's not difficult to do. But, finding the part may be. Blue Rhino, is the manufacturer for Endless Summer Patio Heaters, so start there.
May 19, 2011 | Endless Summer 2009 Open Flame Patio...
Runs for a min then smokes it self out and tuns off other times it will run for 5 min then do it
Check the fuel system for plugged fuel filter, these will have an in line filter and they often get plugged up. Check your fuel lines for holes,kinks or pinching. These will rust in the tank from storing all summer condensation builds water forms then rust. Clean fuel system out good to include the screen in behind the nozzle assembly. While you have the cover off clean out the photoelectric eye and igniter. If the fuel is old change it out as well.
Dec 12, 2010 | Master Heaters Master B115DT 115,000BTU...
Left Patio Heater out for winter, now won't ignite
It could be just a blockage in the pilot assembly, you have to take the head apart to find and clear the blockage. While you are in there you check for a blockage in the main burner orifice as well. If it is just a blockage, then you don't have to replace anything.
If this doesn't get the gas flowing, try replacing the regulator.
Jul 01, 2009 | Endless Summer 1501 Patio Heater
Heater wont light
Perhaps the regulator is going bad, cheap and easy to replace. If not the regulator, then there is probably a blockage in the pilot assembly. If you don't use it for some time, and don't put it inside, or cover it, dirt and insects can get inside and cause a blockage.
You have to take the head apart to clear a blockage. If you are not comfortable with taking the head apart, hire someone to do it.
Jun 11, 2009 | Endless Summer 2009 Open Flame Patio...
Pilot lights but burne wont ignite
not that familiar with that particular heater but in most cases if you can get the same length and can mount they are usually the same milli amp and will work remove the old one and take to a good hardware store they can most likely match up one
Dec 18, 2008 | Uniflame 200209 Open Flame Patio Heater
Burners wont ignite
does unit have thermo-cupling
Nov 23, 2008 | Carrier 52PQ307 Wall/Window Air...
200T would burn
During start up, a hot surface ignitor glows brightley to ignite kerosene, check to see if it is broken
Nov 08, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Master Heaters B70ET Master Logo
336 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Mike Squire
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
