Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Manual for ingersol rand compressor model SS5N5
  • 1388 Answers
SOURCE: looking for a maintenance manual
I worked at a tool rental store for several years that had many ir185 compressors. They had many manuals in boxes that were not used. I just bet that you could call or visit rental yards in your area that rent that unit and find all the information that you need. Talk to the service tach, most will be glad to help if not with manual, the info that you need to keep your machine in good service. IR service kits are available through wwgrainger.com. enjoy
Posted on Nov 27, 2008
  • 1388 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Posted on Jan 10, 2009
ollie reece
  • 1167 Answers
SOURCE: Ingersoll Rand Rotary Screw Compressor, F98928
hi mate on the oil tank take the oil filler plug out and fill it to the neck on the tank good luck
Posted on Jul 07, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 17 Answers
SOURCE: I am looking fo a manual for ingersoll rand t-30
http://company.ingersollrand.com/Pages/default.aspx
Posted on Dec 31, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
Looking for parts list. missing strart capasitors etc.a manual or schedule can help me out.need to buy some parts ingersoll rand dd2t2
Hi johnny camer.
Sorry I could not find a parts list for your compressor model
But I found the ingersoll rand contact number, you can call them and talk to them on the net and get the right parts and manual you need.
Please take time to rate me
http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31052
Aug 31, 2011 | Ingersoll Rand DD2T2 T Win Stack Single...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
I want to change the outlet from it's current 1/2'' to a 3/4'' outlet. I have an IR model SS5N5 air compressor.
To change it like that, you will have to remove the 1/2" outlet, bore it to size and weld in the 3/4" outlet. Don't try it if you're not a pressure vessel certified weldor. If the weld isn't 100% good, you could either have a bad leak (not problem) or it sould shoot the new fitting out like a bullet.
Making a change like this really won't accomplish anything other than empty the tank 50% faster.
Jan 09, 2010 | Ingersoll Rand Compressors 5-HP,...
Where may I purchase or download a complte repair manual for the Ingersoll Rand model # 2475N7.5? Thank you in advance, Gary
I would suggest contacting a local Ingersoll-Rand air center, a lot of times they can make you a copy for little or no charge
Dec 28, 2009 | Ingersoll Rand - Rand Type - 30...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
274 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
