To curtis 5 1 input from output computer 3 quarter inch phone jacks .need a adaptor...If possible,where can I get it?
  • 3,600 Answers
You can get these items at Radio shack Cost's 5 bucks. You did not state if your n the U.S. or not so Hope this helps, You can buy on line at Fry's computer parts and have it shipped as well.
Posted on Sep 14, 2010
Headphone distortion and a hum sound feedback issue when using external speakers
Sometimes empty/unplugged channels introduce noise to the amplifier. You can always try to connect all of the input channels to some external mobile phone/mp3 player, etc. and then set these equipments to the minimum possible volume (mute if possible). This should remove the "atmospheric" audio noise.
Dec 27, 2013 | Hercules DJ Console RMX
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
How to hook it up to new emerson tv without s-viedo connection
Hi,here is my solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
If you want to display your DVD on the TV,than do everything visa versa..as;
**connect "Video Output " RCA jacks or "Optic cable output" of your Receiver
** to "Video input " or "Optic Cable input"
of your TV and make a selection corresponding input of TV
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up to continue f
or Helping out the Community :)
Apr 10, 2011 | Curtis DVD6041 System
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
I have a peavey SP4XT Cabinet . the cross over network has a bi amp input for HF and LF jacks and these work for both LF HF output . Also on this network is two input quarter inch jacks for full range...
The chokes blocks high frequency, the capacitors block low frequency. You would need a digital multimeter to check for continuity. Make sure none of the resistor is burnt, which may not be obvious.
Aug 15, 2009 | Music
How do I play music from my lap top on this sound system?
your laptop has an audio output jack that is 1/8 inch sterio .. your sound system likely has RCA input jacks .. you can get a cable from radio shack that has a 1/8 inch (3.5mm) sterio plug on one end and two RCA plugs on the other ..
plug the 1/8 inch jack into your computers audio output (headphone jack) .. the RCA plugs will connect to the AUX (analog) input on your sound system .. select AUX on your sterio system to select the computers input .. now you should have great sound from your computer . the computer likely provides only sterio information so the multi (7) channel feature of your sound system will have to fake it ..
Jul 24, 2009 | Pioneer SX-315
Is it possible to connect my Altec ACS48 speaker system to my TV?
If your TV has audio output jacks, then yes, you can connect your speaker system to the TV. Run a stereo RCA cable from those output jacks to the audio input jack on the Altec system, using whatever adapter required. You will probably need to convert from RCA jacks to a 1/8-inch stereo plug for the speaker input. Or you can pick up a cable from Radio Shack that has the RCA plugs on one end and the stereo plug on the other, and omit the adapter.
If the TV doesn't have audio output jacks, there isn't any easy way to hook up the Altec.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Mar 04, 2009 | Audio Players & Recorders
Is jack on Zenith TV #SR2571DT6 for component or composite video
the spec on any TV is easy to find and read, as is the whole manual. ever just google it and read it? oops it is relic,
the answer is composite that old.
the online book is so blurry i cant read the page on jacks.
the 1994 no PDF then only now we have horrid scanned pages.
like 30DPI horrid .
first off this is not HDMI, those are all inputs.
SR or SM? is that a typo, ? google finds zero on your model.
omg there are SR TVs made in 1994, wow that is one old TV.
quote wiki. (all are inputs,never outputs)
Most older TVs that have AV inputs will have a set of composite inputs as will as some HDTVs, but typically only HDTVs have the Component inputs. Check your TVs inputs to see what you need. If the input on the TV has only 3 connectors (yellow, white and red) it is composite and if there are 5 connectors in the input grouping together you need the component cable.
this is the SM model, only one I can find.
it clearly says INPUT, see?
and has 2 channels for say 2 VCR's LOL
this is composite due to component jacks not invented in 1994 yet.
sm-z1fpin1ha24aqwl2cxswhash-5-0.jpg not this
the source the RGB colors tell you its component class.
and for for sure the Y signal jack Green.
nor this.
i think 2008 is year of introduction never 1994,
component2-z1fpin1ha24aqwl2cxswhash-5-3.jpg note the 5 cables.
Jan 23, 2018 | Dell Ultrascan 20TX - 20" SVGA Monitor...
I have a 15 inc Curtis LCD Tv which I use as a monitor to my computer and I cant seem to get sound. It used to work well and just recently I moved the computer and now I am using audio cable to connect to...
You need a RCA to mini adaptor which you plug into the speakers/headphone jack on your computer, and then plug the black and red from the rca adaptor into an appropriate audio input on your TV. Both your volume on your computer and TV need to be turned up. I used to use this with my Mac mini and plasma TV to crank out the tunes from iTunes.
May 01, 2008 | Computers & Internet
How to connect a eye trek fmd 200 to my laptop
It is not possible to connect your eye-trek directly to your computer.
you need a signal-converter (vga to av).
Have a look on ebay (e.g. this one on german ebay: http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&Item=380041599591
description is english).
Only the much more expensive fmd 700 has a built-in converter.
Apr 30, 2008 | Olympus Eye-Trek FMD-200 (Black, Silver)...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
