Question about Panasonic TH-42PX500U 42 in. Plasma Television
I have a Panasonic Plasma, believe model TH-42PWD6 and a separate Denon tuner. For a while the colours have been splitting into mostly green and purple. If I flick between DVD and TV it eventually resets.
I had a similar problem with the blue tint going away. I solved it by replacing the terminal board with a new component board I picked up on eBay. You can also use the PC input with a D-sub connector using a component cable adapter.
Posted on Sep 23, 2010
My plasma TH-42PV7HS problem is after on first ok, a few second the picture over green. some people on tv hair is green colour. HELP ME!!
this means your tv has a intermitent problem when the clour ic gets heated up it starts to give you green..so therefore you need to take your tv to a tech to have it repair by replacing the colour ic. good luck.
Sep 13, 2011 | Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD...
Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
Jan 02, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
The pictures are mostly green - like instead of black it shows green
It's called Cyan and it's sound like you are having a problem on your D-board. Look for capacitors bulging out and replace first if not then order D-board
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
There looks to be colour separation on Panasonic plasm viera.
This problems can't be fix,u describing the inner screen of the Plasma pixels burn in.U use this as computer too?U freeze frames in movie,leave video game on pause long period of time,these thing most likely causes plama screen burn in.
Jun 18, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Everytime I use hdmi the colours are mostly green
I have a panasonic th42pa 60a SD plasma and I get the same problem WHEN USING CERTAIN HDMI cables. I had a connexa brand with my samsung stb that i got with the TV and I had no problems., but i had to replace that because one of the ends "frayed" when it was accidently yanked out of the tv socket. A high quality monster cable did the same green screen you describe. The cheapest "Crest" from Big W that did HDMI standard 1b worked fine, but a Rank Arena from Target did not. So buy the cheapest HDMI 1b cable you can, the picture quality and sound is the same as the more expensive stuff. BTW I tried a HDMI 3 way splitter as well and it did the same green screen thing, but it worked on a later model panasonic plasma. I think it is Pana's poor HDMI implementation.
Dec 05, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Possible Tuner Problem?
Go here and get the latest firmware. Find your model on the left side of the web page. http://www.pasctraining.panasonic.com/SpecialApplications/ProductFirmwareDownloads/downloads1.asp
Aug 19, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PX500U 42 in. Plasma Television Logo
235 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
