Question about Mitsubishi VS-50705 50" Rear Projection Television
Misubishi VS-50705 50INCH
My Mitsibushi VS 50705 which turns the power button on for 1 second and then off. Can you help me with this please. I'm un-employed and I'd like to be able to fix it myself if possible. I did unplug it for a few minutes to see if it would reset and that didn't work.
bvr
  • antoonv May 16, 2008
    I checked your recommended web sitehttp://servicemanuals.vstore.ca/ and they don't carry the manual for the Mitsubishi model VS-50705. Now what?
  • Anonymous May 25, 2008
    I too am having the same problem. I got the TV for free and it worked great for 6 months. It shuts off right after I turn it on. Sometimes if I do this three times or so, it will stay on for a few minutes and the picture and sound is great!
  • Mitsubishi Master
  • 8,617 Answers
You would need the service manual to even begin to repair it yourself as it could be literally 50 different reasons why it isnt powering up. I would suggest getting a service manual at the following link , as they will email the manual to you after purchase and then they will provide free tech support to help you diagnose the actual problem , but its a hopeless cause without the service manual. Heres the link.
Posted on May 16, 2008
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Not using the TV in a while may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
4. Some TV's require an input signal (from cable/VCR/DVD/CD, etc) to enable them to power on. Try connecting a cable line or DVD to the TV and see if this helps.
5. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
6. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
May 16, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50707 50 in....
of course..you might want to remove the back panel, and see if all the connections are still secure..
Mar 21, 2008 | Mitsubishi VS-50707 50" Rear Projection...
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
I have a Mitsubishi VS-A50, I turn the power on and the green light comes on for a second then it turns off automatically and the picture and sound never comes on.
Good Day; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. IC8C01 and 02> 267P141030 HIC; STK392-110. These parts are the most common part to fail in this model. If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi VS-50501 50" Rear Projection...
My VS-60607 won't turn on
there is a fuse blown in the television keeping it from staying on. after the shutdown press and hold the menu and device/input button for about 5 seconds and the led will blink a 2 digit code with a pause in between. the code will repeat itself. 2.2 is the most common and points to the convergence ics and 1 or 2 5a pico fuses. 2.3 is the next most common and points to a fault on the power supply. goodluck.
Feb 05, 2009 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsibushi WS-55819 power problems
Wade, My dad has this same set and had the same problem -- Sears came out and replaced the power switch.
Sep 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
