Question about Toshiba Satellite A105-S4344 Notebook
Powers off in exactly 60 seconds. Does this with or without memory and/or HDD. Also with or without power supply and/or battery. Heat sink clean, reseated CPU, new thermal compound, reset BIOS to defaults, latest BIOS
    Problem Solver:
  • 17 Answers
--does it just one time off or will off/on, off/on...like forever ?
Posted on Sep 14, 2010
No post
This sounds like it could be an overheating issue. Some manufacturers use a cheap thermal paste on their processors. If you are dealing with a computer this should be an easy fix but if you are dealing with a laptop then it is much more involved. Go to Youtube and research replacing or removing heat sink. You wont be replacing the heat sink but the procedure is the same except you will need to clean the old paste off your heat sink before you apply more. Don't go crazy with the paste, a little goes a long way, all you are doing with the thermal paste is ensuring full contact between the processor and the heat sink with no air gaps.
Feb 28, 2013 | Dell Studio 1558 Notebook
Powers up but HDD just clicks. Tried several things...
if the hard drive clicks, there's either a serious problem with the hard drive itself, but since you already tested with a drive that is sure to work, it has to be the motherboard. the other post you read, has probably nothing to do with your own problem. try reinstalling your system board's drivers or replace the system board if unsuccessful
Oct 05, 2009 | Gigabyte Computers & Internet
On then off
Remove the memory and clear the cimos battary then reboot the system it will work
Sep 02, 2009 | Toshiba Satellite A35-S1592 Notebook
Medion ram2020 notebook not posting?{md95376}
I have such laptop - Medion ram2020. It doesn't have accumulator. Advise please, what model of the accumulator should be.
Jun 14, 2009 | Computers & Internet
Powers up, won't boot, black screen(not blue), HDD
Try a bios post code - diagnostic card.
Click here, ebay item
will tell you whats wrong. but I can't guarantee that you can fix the problem with it. It depends what problem it is.
May 02, 2009 | Acer Aspire 5100-5022 Notebook
Power supply not staying on
Sounds like when cleaning your computer, you have also cleaned your processors heat sink and fan. right.
if you have done this then there in lies problem.
either your heat sink is not placed correctly
or you forgot to apply a new thermal interface material. because once you remove the heat sink the interface material is of no use. you must apply a new one. and check that you have placed the heat sink correctly and firmly.
Apr 25, 2009 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Do you have any idea why a laptop would power up all the way to Windows and then unexpectedly shut off without powering down? It is still plugged in. The battery is fully charged.
Maybe a heat issue. I had a P4 system once that would do that exact same thing. I cleaned the cpu cooler and fans and added new heat sink paste between the heat sink and cpu. No problems after that. Let me know if this helps.
Dec 15, 2008 | Computers & Internet
Dell Dimension E510 Powers Up, Then Crashes
It's the processor or power supply. I cant be sure of which without checking it.
Check the fan over the processor heat sink to make sure its working cause it could mean that the processor is overheating If the fan turns and then it cuts off this could meant that the processor is dead. or the bios is corrupted. Try flashing the bios, there is a battery on the main boad, remove it. unplug the system first... when the battery is out press and hold the power button for 10 seconds then release. put the battery back in and try to turn it on..
If that fails then try a new power supply or one from another system to to check if the power supply is fine. YOu can aslo bridge the green and any black wire from the power supply's mainboard connector to see if the power supply runs. If all this fails then you may need to replace your processor,, I';d also recommend changing the power supply as well.
Nov 14, 2008 | Dell Computers & Internet
Hello
This could be a number of different problems that causes the irregular shut down. It could be the power supply, battery, memory, processor, fan, heat sink, or motherboard. Try these in this order. Check the power supply with an ohm meter for the proper output. Remove the battery and run on power supply only. Remove the memory, and try running with one chip then the other. If the machine seems hot when shutting down, clean the fan and heat sink, also remove the processor, blow it off with air and seat it back in properly. Check all connections on the motherboard. If at this point the problem sill persists, then it's a significant problem with the motherboard or a motherboard component, and you should take it in for a professional diagnosis.
Aug 18, 2008 | IBM ThinkPad T30 2366 Notebook
Power of
right i no what your saying but it is deafinatly over heating sound like your heat sink needs a clean? if your care full you can do it your self rother than pay some one ells to do it it not hard just renove battery and on the machinr arrows show you wear the screws are located i did mine with a paint brush a artis one so why your in there give it all a brush out
Aug 15, 2008 | Toshiba Satellite A10 Notebook
Toshiba Satellite A105-S4344 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
