Question about Toshiba Cinevision DVR2000
The clock on the toshiba DVR20 DVD/Video Recorder set automatically when the player was connected for the first time. However the clock is incorrect. How do I reset this. It says you cannot reset once the DVB channels are set
5 Suggested Answers
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: I have a DVB-T VCR/DVD
Spent much time in the loft adjusting the aerial. Everything now OK
Posted on Jun 29, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
  • 1623 Answers
SOURCE: Can't get my Toshiba DVR20 to play Region1 dvds. A
is it a region 1 dvd player?
Posted on Mar 11, 2011
Hi my Toshiba DVR20 combo plays a vhs tape for 5 seconds then turns self off any advice please
Tape transport mechanism fault. Contact any service technician. Tape do not run properly. Might be the fault of some belt/s or loading wheel.
google.com/+GopakumarGopalan
Jun 29, 2015 | Toshiba DVR20KB DVD Recorder
I want to play region 1 dvds on my toshiba dvr2o
Go into system , then disk settings , you should have a option to play NTSC on PAL select this and your region 1 discs should play with no problems. NTSC is region 1 format
Oct 10, 2014 | Toshiba Dvr20 Digital Dvd Recorder And Vcr...
Which dvd +r discs are compatible to record on toshiba dvr20?
You can use any DVD+R or DVD-R disk .
Your device is compatible with
  • CD-R
  • CD-RW
  • DVD-R
  • DVD-RW
  • DVD+R
  • DVD+RW
  • DVD Video
  • DVD VR (-R/-RW, +R/+RW)
Apr 24, 2014 | Toshiba Dvr20 Digital Dvd Recorder And Vcr...
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
The clock on our RD-XV48DT is showing the incorrect date (4th March instead of 1st March). We cannot re-set the clock manually (it just reverts to the wrong date), and we can't turn off the "clock...
i've got the same problem. looking arround the internet lots of people had the same thing last year & it corrected itself the next day. (2 march)
fingers crossed
Mar 01, 2011 | Toshiba D-R5 DVD Recorder
Setting the clock on a Wharfedale DVDRHD400F
Try scanning for channels. It may well download time and date automatically.
Dec 21, 2007 | Wharfedale DVD-M3 DVD Player
Dec 03, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba Cinevision DVR2000 Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
