Question about Refrigerators
Admiral refrigerator (top/bottom) has stopped cooling. what could be the problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 55 Answers
It could be lack of gas.
maybe
Posted on Sep 14, 2010
I have a black admiral fridge( freezer on top, not side by side) the vents on bottom of freezer froze with ice and fridge stopped working completly
the evaporator coil or freezer coil need for flushing due to clogging on vents have a presence of oil need for reprocesses and charging of refrigerant after refrocessing.
Jan 22, 2011 | Admiral Refrigerators
Freezer works fine, but fridge won't stay cool. I replaced the defrost timer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
How about the fan at the condenser??? Is it running??? Is air being circulated from the freezer to the fridge...if not then find out what is stopping it...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 12, 2010 | Maytag Admiral Top-Freezer Refrigerator
Admiral gs22a8d3 freezer freezes up fridge stops cooling need to unplug to defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 18, 2010 | Admiral 26 cu. ft. Side-By-Side...
Our fridge freezer (Admiral GS20C63EV) stops cooling and needs to be turned off with doors open to difrost overnight. it works for a few days and again it stops cooling! both the fridge and freezer stops...
Good day,
Step one. Remove the light guard in the fresh food section and where the main thermostat is located is a slot where you can insert a screwdriver. This is where the timer is. With the machine running, turn the shaft clockwise until the machine shuts off. Wait 35 minutes. If the machine comes back on, the timer is o.k. if not replace it.
If the timer is o.k move over to the freezer side. With the machine having been on for at least 6 hours remove the rear panel.
Inspect the cooling coil closely. It should have a frost coating from bottom to top. If the top coils are clean, you have developed a freon leak and have a serious problem.
If the coil is active top to bottom, then you will need to replace the dual glass defrost heaters and the defrost thermostat. One or the other may still be good at the time but it isn't worth the hassle to go into the system twice.
Installing them is tedious but doable. Take your time and keep track of how it comes apart. It's a monkey see monkey do job.
Careful on pulling the new wires.
P.S.The top coils wil not be as heavily frosted as the bottom ones but must have an active coating of frost on them.
May 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
How do you remove the doors on an Admiral refrigerator?
Unscrew the top bracket from the top of the refrigerator. Once you get that off the door will lift off the bottom bracket.
Hope this helps :)
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
I have an admiral refigerator (top freezer) less than 3 years old. The unit sat in a vacant house unplugged for about a year and now will not cool. Any suggestions
Good day,
Check in the freezer compartment to see if you can hear the fan motor running. They will freeze up if left off for extended periods of time.
Another fan motor on the bottom back near the compressor can suffer the same fate.
If both check O.K. Then since it's under 5 years you could have a refrigerant leak or a compressor problem that is under factory warranty.
Call your selling dealer for service.
Feb 05, 2010 | Maytag Admiral Top-Freezer Refrigerator
Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Oct 23, 2009 | Maytag Admiral Top-Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
