Question about Xerox DocuColor 12 Color Copier
Fault code 10-390 on start up, restart does not correct it?? Help!!
    Sergeant:
    Champion:
  • 251 Answers
Xerox says this is a Fuser Jam Fault. If you go to their web site (click HERE) you can click on Fault Code Search to get more information.
Posted on Sep 14, 2010
Hi i have a 2009 diesel x type jaguar when first starting car i have gearbox fault and car goes into limp mode but after 10 minutes driving when you switch off and restart car everything is fine
When the limp home is engaged by the processor a fault code or codes is set in memory, it may be a Transmission code or engine fault code. You nee it tested with a full function scanner, a code reader will not read the transmission faults.
Jan 19, 2017 | Cars & Trucks
2001 cadillac eldorado dies shortly after a cold start. Will always restart, happens when parked, and while driving. I am mechanically inclined but could use some expert advice on this one, thank you
best advice is to have the fault codes read first
It is possible that a fault with an ambient temp sensor will show, fault MAF/VAF sensor or BARO sensor
get the codes first then read the workshop manual on how to test and where they can be found
because it starts and then restarts after stopping , the fault is indicated in that area
Feb 25, 2016 | Cadillac Cars & Trucks
Buick Rendezvous Shuts off when accelerating but starts right back up
Hello
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Oct 01, 2012 | 2005 Buick Rendezvous
Please help!! i was driving my Peugeot (Expert) E7 2009 Taxi when i had a sudden burst of speed followed by the engine cutting out and the vehicle rolling to a halt. the engine would not restart unti
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Jul 24, 2012 | Cars & Trucks
1997 chrysler town and country dies at random and takes a few to restart
You must have a fault test run on the engine control computer (called an OBD2 fault code scan), there is likely a fault code or two stored that will help diagnose the problem.
May 24, 2012 | Cars & Trucks
It is Vitara sidekick 1997 model. Water temp sensor is replaced, the fault code erased, when I start the engine and drive, every thing looks nice, but when I switch off the Ig key and start the engine next...
you can get codes with out scan tool, this is done by counting the engine light flashes, for example a long flash is the first didgt and then faster blinks would be the next number, for example long flash long flash long flash= 3 then fast flash ,fast flash, fast flash, fast flash =4 which would be code 34, to get the codes look in the engine compartment in front of the battery is the connector, you will need a small wire to jump two terminals, jump terminals with wire then turn key on and count flashes, i will give you a diagram to locate connector and it will show you which terminals to jump look at connetor closely to make sure you are jumping the correct terminals, you can turn the key off and on to restart the codes again,this may take you a few trys to get the hang of it but you can restart the codes by just turning the key off and back on, when your done just remove the jumper wire,also a diagram is enclosed to show you how the flashes go, hope this helps ,good luck.
Mar 05, 2011 | 1993 Suzuki Sidekick
Fault 10 appeared
Fault 10 indicates "No Water is Dispensed."
Solutions =>
– The water tank is not inserted properly. Take it out and reinsert correctly.
– The water tank was not filled correctly during the descaling process. Fill the water tank up to the correct mark.
– After fixing the fault, the machine turns off then on again. Start the desired preparation again.
– If the message still appears contact Technical Service
See page 52 for Fault Codes and Solutions in the owners manual.
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Sep 07, 2008 | Miele CVA4070 Coffee Maker
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Xerox DocuColor 12 Color Copier Logo
307 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
