Question about Kenwood KGC-4042A 5-Band Car Equalizer
On the Kenwood kgc-4042a the power ground and the remote wires how do they go in order
SOURCE: power unit on test for Kenwood kgc 7043
should not need the head unit.open up unit and start testing continuity along wire an board.possible break in connection.
Posted on Mar 06, 2009
  • 102 Answers
SOURCE: owners manual for my kenwood kgc-9400 graphic eq i want to inst
download from Kenwood's website
Posted on Mar 12, 2009
  • 86 Answers
SOURCE: I need a wiring diagram for my kenwood KGC-4041
Most of the time you plug your RCA wires which are red and a white solid colors only, into the equilizer. Plug in every thing that you want to equalize many which speakers do you want to sound better. also check kenwood usa .com look for support your model # and downloads manuals. It's Free. Hope this Helps.
Posted on May 06, 2010
  • 5 Answers
SOURCE: I have just installed a Kenwood KGC-4042A
check for good ground
Posted on Sep 29, 2010
  • 147 Answers
SOURCE: what is the blue/white wire on a kgc-6042a car
blue/white would be the "turn on signal" wire, i.e. one that gets 12v when the unit is supposed to be on (this would correspond to the amp turn-on or power antenna wire from your CD player) whereas the yellow wire is the 12v constant power wire.
Posted on Mar 07, 2011
Im looking for a kenwood kgc 9044 wiring harness. will a standard 16 pin cd player harness work?
any regular kenwood 14 pin harness will work use the yellow for your battery wire the black is still ground and the blue&white striped remote wire is your switched power just hooked one up today sounds Amazing!!! for it's age!
Feb 10, 2011 | Kenwood KGC-9044 11-Band Car Equalizer
What is the blue/white wire on a kgc-6042a car equalizer and the yellow which is the power
Jan 25, 2011 | Kenwood KGC-6042A 9-Band Car Equalizer
How to hook up a equalizer
i believe you need to be running an aftermarket amplifier to use this E.Q. does it only have RCA inputs and outputs on the back of it? if it does, you'll need to run the rca's out of the radio into the E.Q. then run the rca out's from the E.Q. to the inputs of your amplifier. and of course there's probably a constant 12v, a switched 12v, and a ground you'll have to wire up.
Feb 17, 2010 | Kenwood KGC-4042A 5-Band Car Equalizer
I understand the diagram with the +12v and the gnd wires, but does the third wire only work with other Kenwood products? It appears to be a "sense" wire or similar that feels the presence of a powered-up...
Hello davec99,
The third wire is commonly called a "remote" wire and is used to turn on other devices, such as an amp, connected to the audio system. When the equalizer is off, there's no signal on the wire. When the equalizer is on, a low current 12V signal is on the wire, signalling the remote device to turn-on.
Hope this helps.
Jun 12, 2009 | Kenwood KGC-4042A 5-Band Car Equalizer
Power unit on test for Kenwood kgc 7043
Feb 24, 2009 | Kenwood Car Audio & Video
Power connection
Theres supposed to be a harness that plugs into that connector. It will have the international color standard wires. Contact a kenwood dealer to get the harness.
Sep 14, 2007 | Kenwood KGC-6042A 9-Band Car Equalizer
Which wire is power and ground
generally red is the ignition wire, black is ground, orange is 12+ all the time, a yellow could be the same....it would be more helpfull if you would give the model number of the eq
Jul 13, 2007 | Kenwood KGC-4042A 5-Band Car Equalizer
Kenwood KGC-4042A 5-Band Car Equalizer Logo
60 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
