Question about Rancilio Silvia Espresso Machine
Miss Silvia power button and lights come on. all functions work but does not heat. I check the heating element and I have 120v across and 40 ohm resistence. any clues?
Try hitting the reset button.
Posted on Jun 21, 2008
Electric Travel Cooker, Sanyo RN-AVA308, will not heat up, where can I have it serviced?
I have the same unit and the same model number. Mine also not heat up. upon investigation I noticed the heating element has a 4 wires which I believe each pair (2 wires) meant for 100/120V and the other one is for 220/240V. I checked 2 wires (1 pair) has an open circuit while the other pair is ok. I directly connected the heating element to the power and it was heated up. I measured the resistance and it was around 78 ohm. from my lame calculation this is for 100/120V heating element. the 220/240V was busted.
Since mine on 220/240V power grid, to use the working 78 ohm heating element the estimated power would be P=VxV/R, around 738W which is way too high than the rated power (365W) for this voltage. I plan to add the dummy resistor 82 ohm + 78 ohm heating element to reduce its power around 370W. Hope it works.
Mar 23, 2011 | Kitchen Appliances - Others
Our rancillo silvia does not heat up water or make steam. the power light shows on.
Sounds like the heating element is fried, you will need to find a local person who understands basic electrical troubleshooting with a meter. Take the top off and have somebody meter voltage across the heating element electrodes if there is voltage ther,e but the machine is cold, your heating element positively absolutely has gone bye bye. We can repair this
Mar 04, 2011 | Rancilio Silvia Espresso Machine
I have a Whirlpool LER8648LW0 and it will not heat up. I had to change the breakers and once I did that no more heat. Everything else works fine. The only difference in the breakers is the old ones were...
if you had heat in the dryer before you changed anything in the electrical box then i doubt very much it has anything to do with the dryer.if you have a meter you can check at the block where the cord connects to the dryer and make sure you have 240 volts coming to the dryer before you start messing with the dryer
Mar 03, 2011 | Whirlpool Dryers
I have a duet model 9200lw1 it has no heat I have replace the heater element still no heat when the dryer is on both sides of the element read 120v and it reads 120v at the high-limit thermostat and It...
you need to actually check the resitance on the high heat thermostat and cut off... make sure if your meter has a ohms and a beeper on it it should beep when you test across it with the unit unplugged and the wires off the terminals of the limit.... when the heater is heating if you test across the two terminals of the heater if working properly you should get 0 reading.
make sure you have 220-245 volts coming into back of unit even if you think it is check it the unit will still have a light and tumble with half power. you need to test across terminals at same time and should get the above voltage..... good luck to you hope you get it fixed..... good luck
Jan 08, 2011 | Whirlpool GEW9200L Electric Dryer
Heating element not working - all switches ok. Where can I buy a new element.I am in the MIdwest. Mike
Will it heat in the steam mode? If it doesn't heat in the steam mode it might just be the reset button on the front of the boiler. There are 2 black wires on the high limit thermostat. In the middle of the wires there is a red button. Push it and then see if it heats. If that didn't do it check the element with a ohms meter. If it doesn't have a reading then its the element and you need to change the boiler.
Dec 04, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
My Rancilio miss Silvia coffee machine is not heating water any more. Which part should be replaced? Thank you
Could be a switch, a themostat, a wire connection, or the boiler element. Someone with a volt-ohm meter will have to help you.
Once you figure it out, you can get the parts here
Rancilio Silvia Parts
Dec 09, 2009 | Rancilio Coffee Makers & Espresso Machines
Rancilio Silvia stopped heating up.
Check to see if it will heat in the steam position. If it does, then you have a bad brew thermostat, and just need to replace that. Its the one with the red dot. If not, run some water through the wand and see if it is milky? If its milky you have a blown heating element. You can also do an ohms check in the element. There should a reading between the element terminals of 12 to 16 ohms. If you have no reading, your going to have to replace the boiler.
Oct 26, 2009 | Briel Coffee Machine Multi-Pro...
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't heat
Jess, the model number comes up as a Crosley electric dryer. Start first at the terminal block where the cord attaches. Should read 120V from each end to center and 240V across the two outer. If this is ok, check the thermal cut out, this will be the top limit switch on the heater housing. Should read closed. Ohm out the element itself with the wires off, should show continuity. You should have 240V across the terminals on timed dry. If that checks good, go to the motor harness. One leg of power to the element goes through that switch. Check that all the wires are intact in the harness and reseat it. Check these things back.
Jan 25, 2007 | LG WD-14124RD Front Load Washer / Dryer
Rancilio Silvia Espresso Machine Logo
132 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
