Question about Samsung DLP HL-P5663W 56" TV
When you turn on the TV it makes this buzzing sound like something is spinning inside the TV. After a while the TV cut off on its own. It has a new bulb in it.
  • 122 Answers
Check the fan that cools the bulb. if its rubbing something that would make the buzzing sound, and if its not cooling the bulb it will shut off when it over heats.
Posted on Sep 14, 2010
I turn the tv on and there is a constant buzzing sound what is it?
Hello
If the picture is correct in all resepect, and only a buzzing sound only comes from its inside circuit, it will be due to a loose core fittings, on any one or two ferrite cored transformers inside the power supply sytem. There are transformeres of small and large types, both in power supply and other boards. We have to find out which transformer makes this buzz sound during working. For this, you have to open your TV, and power it ON, and listen the the sound carefully, and detect the transformer which makes this noise. After finding the exact one, this loose core contact can be fixed with the help of Super Glue or similar fast acting adhesive. Just put three or four drops of adhesive in between the core will rectify your problem.
If there is no picture at all and a buzzing sound like this is heard from your TV, the inside circuit has some short in it and has to be detected and rectified. OK>
May 01, 2011 | Polaroid FLM-323B Television
Kenmore 80 series makes buzzing noise but won't drain or spin, smells like burning if left on spin cycle.
That sound a lot to me like yall have something inside the pump. Over the years I have found all kind of things from ladies undergarments to shoes strings. themobilian_1938.jpg
Video pump replacement:
Service manual
Mar 16, 2011 | Washing Machines
Maytag Model #MAT13MNAGW When the machine gets to the spin cycle it doesn't spin but makes a buzzing sound. Something like the buzzing sound that a welder makes when the rod sticks.
this means that there is something stuck inside your drain pump.if you still have water in the machine you can use a wet/dry shop vac and attach it to the end of the drain hose and remove all the water in the tub.
once that is done check your drain pump for obstructions if there is no obstruction look at the hose that comes down from the bottom of the tub to the drain pump
Feb 08, 2010 | Washing Machines
Buzzing from inside when off.
hi!if your t.v is always on stand by power mode and there is a buzzing sound the problem is in power supply section,you need to check for weak capacitors.
Sep 08, 2009 | Emerson EWF2004 20" TV
Wii makes a horrible noise while loading or ejecting the disc
Hello my name is Tim Ehrhart, I repair 360's and have had this problem with them and there problem is that the magnet that holds the disk in place gets stuck and makes a grinding noise that sounds horrid. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 12, 2009 | Nintendo Wii Console
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Samsung DLP TV is making a buzzing sound. Sounds like something spinning. Can hear it speed up to full spend when turned on and slow down and stop when powering off the TV. Loud at times.
More than likely this is the cooling fan. I have a Samsung DLP myself, and at times, I can hear the fan running also. There could be something wrong with the fan, but I kind of doubt it. Just make sure that the TV is in a spot with lots of ventilation....otherwise, you might have to live with this noise.
Hope this helps!!
Chad
Oct 08, 2008 | Televison & Video
Recentley my tv just turned off. I heard a buzzing sound which happened the 1st time my bulb went out. So I ordered a new one. When the new one was put in it worked for 5 minutes then turned off and...
This could be a couple of things. Look at the cooling fan and be sure that it can spin freely. If it is stuck, the buzzing could be the motor trying to spin the fan. Other than that, the ballast could be failing as well. This is the part that "fires" the lamp. Examine the fan first and let mw know what happens.
Dan
Jul 22, 2008 | Televison & Video
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Samsung DLP HL-P5663W 56" TV Logo
190 people viewed this question
Henry  Thomas
Henry Thomas
