Question about HP DeskJet F380 All-In-One Printer
I have an HP Desktop F380 All-In-One. When I print on it, there are little blank lines through the text. A friend told me that I need to clean the heads. Is this right, and if so, how do I do it?
  • brocline Sep 14, 2010
    It got me looking and thinking right. I looked up the owner's manual on the hp site. It doesn't recommend clean the head directly, but instead showed how to clean the copper colored contacts on the ink cartridge.
    Genius:
  • 1,478 Answers
Your friend is very right, follow the guideline below to clean the print head of your printer.
First, remove your ink cartridges from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Some printers, such as many Canon models, feature removable print heads that give you easy access to the print head and its nozzle(s). Many other inkjet printers don’t have this feature, so you’ll have to do your best to work around parts in your printer. Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out.
If you have a removable print head, remove the ink cartridge from the print head and take the print head out of your printer. Put some hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it’s really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle. This should get rid of any dried ink that was loosened during the soaking.
Take care.
Posted on Sep 14, 2010
  • 1 more comment
  • Jimoh Adeleke Muyideen Sep 14, 2010
    Preferably, hot water will do the cleaning better
    How do I know if the print head is removable? I took the two ink cartridges out, but i don't know where the head surface is that I should be cleaning.
    Thanks, you got me looking in the right places and thinking. i looked up the owner's manual on the HP site, and figured out that what I needed to do was to clean the copper colored contacts on the ink cartridge.
Hp dj 3050 print not dark enough
Have you tried changing your printer settings? It may be set to draft instead of normal.
Jan 10, 2014 | HP DeskJet F380 All-In-One Printer
HP all-in-one F380 only prints top half of the page, and sometimes that is pretty faded. What to do?
Replace the ink-cartridges, because they are just about empty.
When ink is pulled from the cartridge, there is just enough ink to print a "low-density" page,
or a few lines of text, but there's not enough ink to "freely" flow, on demand, to ink a full page.
Jul 30, 2011 | HP DeskJet F380 All-In-One Printer
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
Word 2003 files will not print. blank pages
Your printhead nozzle might be clogged up,
try deep cleaning ph 2x then try again
Dec 20, 2009 | HP DeskJet F380 All-In-One Printer
The papers come out blank on my hp deskjet f380
check your printer ink-jet, make sure there is ink in it.
Oct 17, 2009 | HP DeskJet F380 All-In-One Printer
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet f380 print and scan function copys with a wide black
clean the print heads and run clean cartridge utility from printer properties window.after that
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.
Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
278 people viewed this question
Seeker5211
Seeker5211
