Question about Ariston Technologies L63 Free-Standing Dishwasher
L63 Salt light is flashing
Salt light and 2 other lights on controls are flashing. Started cycle, then once water wasm in the cycle stopped and the lights flashed. The water wont drain out now
Regards
Kristen
  • 3 more comments
  • pipwalker11 Nov 01, 2008
    my ariston dishwaher has two lights flashing and will not drain.
    pip
  • Anonymous Jan 08, 2009
    Does anyone know what it mean when the salt light is flashing?
    Thanks Sandy
  • JirinaH Jan 11, 2009
    Hi, I have the same problem. I have been using 5 in 1 tablets. Salt light is flashing and after about 10 minutes in washing on ECO, the machine stopped working and the first two lights are flashing as well as the salt one. The water is on the bottom and would not drain. I have cleaned the filter, sprayer arms and added 1kg of salt. But it won't work - still flashing first two lights and salt indicator. Thank you in advance for your help. Jirina
  • Anonymous Jan 17, 2009
    hellp what sort off salt do you put innnnn
  • mirela2601 Feb 15, 2009
    i have the same problem. pls help me
Goes for short time and 2 ljghts flash the red salt light wont go on
Posted on Jul 06, 2008
Water sensing red light showing in electrochlor 25 SC
check water at pool place if ok replace sensor
Nov 02, 2017 | Pool & Spa
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 | Dishwashers
I want to know where to put my dishwasher tablet in my Kenwood KDW4TTSL please. And where does the salt go and how much do I use?
Im presuming that you don't have a manual. If you would like one, you can download a free PDF from here:
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
According to the manual:
There is a recess on the right hand side of the door for detergent (Picture on page 6 of the manual). You can put a tablet in here.
With regard to salt (Also on page 6):
1. Unscrew the cap from the salt container
anticlockwise, which is located on the right side of the
inner box.
2. Load the salt into the container. Each time you may load 250g of salt, which can be used for 15
cycles.
3. Fill the water into the salt container until a small amount of water comes out(it is very important
when you use it for the first time).
4. Screw the cap back carefully.
Note:
1. Load the salt before the beginning of wash cycle so as to prevent corrosion.
2. Load the salt when the salt indicator light in the control panel is illuminated.
3. Only use dishwasher salt.
Jul 19, 2011 | Kenwood KDW4TTSL Dishwasher
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
I have set the run time on my salt water pump and then locked it back to pushing the buttons it shows the time but there are no green lights showing. Did I forget to do something?
one the run time is set you have 2 options
wiat 2-10 minutes for the system to lock itself and for the second green light to come on this mean you are generating
The other method is to lock it yourself do this by once your hours appear for run time then press and hold down arrow again till beep then press and hold up arrow till beep the hour will stop flashing and in 2-10 minutes your second green light will come on
Jun 12, 2010 | Intex Automatic Salt Water System for ...
Machine does not want to start on any cycle.
Check salt chamber and add salt if empty. Check your inlet water flow.
Apr 14, 2010 | Dishwashers
Salt light flashing added salt light went to orange no longer flashing but no chlorine lights will light has been 29 hours
All salt generators need at least 4-5000 parts per million for up to 30 days for the generators to re-generate salt. it takes chlorine to combined with the generator and salt to regenerate salt. Salt generators do not make salt from water that is not chlorinated first.
Try This and you will re gererate chlorine.
The Pool Tech
Jul 16, 2009 | Zodiac Duo Clear System Chlorine...
After going thru the Start up set up our Intex
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
Sep 14, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Ariston Technologies L63 Free-Standing Dishwasher Logo
1,134 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
