Screen flickers then goes black system still ok i can hear my musik playing i hooked up big monitor it did the same so the back light is ok and the inverter isnt the case hear either how do i check the vid card and can it be replaced
    Master:
  • 633 Answers
Check in safemode to make sure that it is not a driver or a display resoultion issue.
Posted on Oct 17, 2010
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Black screen w/ faint image
It sounds like the inverter to me.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Mar 31, 2012 | Computers & Internet
When I play some games on my syncmaster 215tw, the screen goes black after 5 minutes. I have to reboot everytime to get the screen back on. The blue light flashes but i cant do nothing until i reboot....
that means your VGA is not big enough to run the game.This problem is not from the monitor but your system.I suggest an upgrade in your system to enhance better performance.
Aug 02, 2010 | Samsung SyncMaster 215TW 21" LCD Monitor
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
Monitor goes black when i turn it on
just a big hardware problem in your monitor
Sep 23, 2009 | Samsung SyncMaster 216BW Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
I have a fujitsu lifebook N6460 the screen flickers and goes out
Sounds like you back light or LCD inverter is going out, If you don't hear a whine then it is just the LCD screen, if you hear that whine then it is the inverter. An inverter will run 40-60 dolloars as opposed to and LCD screen which usually start around 100 and go up...
Hope this helps, if so please rate my solution accordingly.
Since it seems as though you dont move it very much you might be able to hook an external monitor up to it and using the Fn+F5 button swap it to use the external monitor untill you can get it repaired.
Mar 18, 2009 | Fujitsu LifeBook N6460 Notebook PC...
Monitor on emachines computer is black and the on/off light flickers screen will not come on
First make sure the power cord is plugged in both ends (in the wall and in the monitor).
When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow.
A monitor light that just flickers and goes off is probably an indication that the monitor has failed.
I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Jan 22, 2009 | E-Machines eMachines Monitor E15T4
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Computers & Internet Logo
481 people viewed this question
David Payne
David Payne
